In most cases that is caused by a slow water leak in that side of the dual water control valve. When your ice maker calls for water it turns the water on for about 7.5 seconds and water is sent to fill the ice tray. But if water should slowly
ooze by the valve while off the water tends to freeze in the end of the fill tube causing the ice to make the water go everywhere but the correct place. Sometimes the fill tube can be cracked by this problem. Using a hair dryer will help for the temporary time. Best thing to do is turn the water supply off at its source and remove the water control valve and clean out any debris that may be causing the valve to stick open and a
pre-filter before the valve is needed in severe cases. Sometimes the valve has the seat damaged and will need replaced. Yours is part number=>
4389177 If you have questions or require more help please let me know, Thanks,
Sea Breeze
