Question about HP Pavilion a1210n (ED895AA) PC Desktop
Age of Conan (Hyborian Adventures)
Trying to load program - can barely get the disc recogonised (doesn't autoload) then when trying to setup.exe getting back not a win32 application error msg. Windows Explorer keeps freezing and desktop reuturns upon opening the Disc tray. any ideas (yes firewall and virus protection are off) I also have a GForce FX5500 videocard and extra ram in addition to basic a1210n
  • johnwebber May 20, 2008
    Key Features
    Operating SystemMicrosoft Windows XP Media Center 2005 Edition
    Form FactorTower
    ProcessorAMD Athlon 64 2.2 GHz
    Installed Memory512 MB (DDR SDRAM)
    Recommended UseHome Use
    Processor
    Processor TypeAMD Athlon 64
    Processor Speed2.2 GHz
    Processor ManufacturerAMD
    Processor UpgradabilityUpgradable
    Max Processors Qty.1
    Installed Qty1
    Socket TypeSocket 939
    Motherboard
    Bus Speed2000 MHz
    Video Output InterfacePCI Express
    Memory
    RAM TechnologyDDR SDRAM
    Installed RAM512 MB
    Installed Cache Memory512 KB
    Max Supported RAM4 GB
    Supported RAM Speeds400 MHz
    Number of Memory Slots4 x 184 Pin DIMMs
    Technical Features
    Expansion SlotsPCI x 3
    Integrated Input/Output PortsPS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · USB 2.0 x 6 · RJ45 Lan Port x 1 · FireWire (IEEE1394a) x 2 · USB 1.1 x 1
    Expansion Bays2 x 3.5" (External Access) · 2 x 5.25" (External Access) · 1 x 3.5" (Internal Access)
    Memory Card SlotsMultiMediaCard · Micro Drive Memory Stick
    Hard Drive
    Controller TypeSerial ATA
    Hard Drive Capacity200 GB
    Hard Drive InterfaceSerial ATA
    Hard Drive Rotation Speed7,200 RPM
    CD / DVD
    Optical Drive TypeDVD??RW Dual Layer
    Optical Drive Read Speed16x (DVD) · 40x (CD)
    Optical Drive Write Speed40x (CD-R) · 8x (DVD-R) · 16x (DVD+R) · 2.4x (DVD+R Dual Layer)
    Optical Drive ReWrite Speed4x (DVD+RW) · 24x (CD-RW) · 4x (DVD-RW)
    Audio / Video
    Audio Output TypeSound Card · Headphones · Line Out
    Graphic ProcessorATI Radeon X200
    Audio InputMicrophone Jack · 2 x Line In
    Video Out Ports15 Pin D-Sub VGA port x 1
    Integrated AudioAC'97 Audio Codec
    Modem
    Modem TypeFax / Modem
    Networking
    Data Link ProtocolEthernet · Fast Ethernet
    Networking TypeIntegrated 10/100 Network Card
  • Brian Canute May 11, 2010
    what is your operating system please
I'm having the exact same problem, not sure why
Posted on Jun 01, 2008
  • 56 Answers
Have you tried a seperate pci sound card compatible with your game
Posted on May 26, 2008
How can I get the disc to play on a windows vista 7 hp computer
There are a couple ways you can do it , first try " Windows XP Mode for Windows 7 " , http://www.microsoft.com/windows/virtual-pc/download.aspx this will link you to Microsoft's Direct Download Page , once you have it downloaded , install it & reboot your pc . You should then be able to install the disc in the virtual xp enviroment . Another option is trying the built in compatibility mode , place the disc in the pc , open the disc's main folder using windows explorer . Then right click on the executable file ( normally named setup.exe ) select properties from the drop down menu , click the compatibility tab , select run in " windows xp sp2 " mode & check the box at the bottom " run as adminstrator " . If you are unable to install it after trying both of these methods leave me a message here with a email adress or instant messenger id so I can contact you directly .
Apr 17, 2011 | The Learning Company The ClueFinders 4th...
Can't find setup.exe
The term "setup.exe" is like trying to find Untitled.doc.
here's a example: I'm trying to look for my "essay". It's vague and doesn't really tell you what type of essay it is, nor the name.
Setup.exe might have been renamed from a real file name.
Or it is file names for some viruses so people end up opening the .exe to see what it is.
Mar 05, 2011 | Computers & Internet
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
Feb 23, 2011 | Nova Development Print Artist Version 22...
I am installing Quickbooks Pro 2005 on my Windows 7 computer. I got past the flash error but encountered a fatal error when trying to run quickbooks. Any fixes?
Try this:
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Jan 22, 2011 | Intuit QuickBooks: Pro 2005 for PC
Would like to load some of the older games i have onto vista but they are not 64 bit compatible, looking for free download to correct this problem
Run the Program Compatibility Wizard
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
Apr 22, 2010 | Microsoft Windows Vista Ultimate Edition
Titans age of mythology expansion disc will not
You need to know that your system is up to running the software, the requirements should be included on the game. Sorry but I can't give better information as I don't have that game.
Sep 29, 2017 | Microsoft Age of Mythology: The Titans for...
I just purchased my 2nd Asus My Pal A626 Pocket PC. And I cannot run the setup program on any of my 5 computers. It tells me I need Flash 8.x or higher and I have Flash 10.x or it says I may have a...
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
Nov 03, 2009 | ASUS MyPal A626
Cant seem to load my footie manger 09?put disc in but cant find how to load the game
Run the setup.exe, install.exe or setup.msi program on the CD drive in which you placed the CD.
Ex:
D:\setup.exe
Mar 06, 2009 | Microsoft Windows XP Professional With...
Screen display problems when running Adventures in Typing
I bought this for my daughters back in 2000. Now I find my mother wants to become a silver surfer and she would like to learn how to type letters. I tried using Adventures in typing on her laptop and saw that there were compatability issues. After a lot fo experimneting I found asloution that works every time and is as simple as can be. this is what I did (and printed out for my Mum:-)
Hi Mum :-)
Video problems with Adventures in typing with Timone and Poomba
There are compatibility issues with Windows Vista and this program
To overcome these problems we need to force windows Vista to use an
older Video format (from the days when the program was first published).
A short cut has been created and placed on your desktop.
The compatibility (properties) on the short cut have been set to –
  • Windows 95
  • 256 colours
  • 640 x 480
To create the short cut –
Place the CD-rom in the Disc bay and hold down the Shift key while the the CD-rom boots up. This prevents Autorun.
Now use Windows Explorer to look at the files and folders on the CD-rom.
Look for the Setup.exe file.
Right click on it to create a short cut that will be placed on your desktop.
Go to the short cut and right click on it to select the properties.
Now change the compatibility to the settings mentioned above.
Remove the CD-rom from the disc bay.
This is how to use the program Adventures in typing with Timone and Poomba on a computer running Windows Vista
  1. Do not put the CD-rom in the computer until you are asked
  2. Indentify the shortcut/icon on your desktop to start the program
    Click on this shortcut/icon
  3. When the computer asks for the CD-rom, place it in the disc bay and wait for the program to start.
  4. Use the program as normal.
  5. To quit the program so that it saves the progress you have made – use the QUIT symbol in the program’s screen
  6. When the program has shut-down, remove the CD-rom from the disc bay
Note that steps 1 through to 7 have to be done every time the program is started and stopped.
You will not have to do anything to put settings back to where they should be – Windows Vista will do that automatically.
This is how to stop any program if you are having problems and can not see how to stop it.
  1. Press the following two keys together Ctrl Alt
  2. While holding those two keys down, press a third key – the Delete key
  3. A menu will pop up.
    Click once on the Task Manager option
  4. A new window will open with a list of the programs that are running on your computer. Click once on the program that is causing the problem.
  5. At the bottom of the new window click on End Task
  6. The program that was causing the problem will be shut down for you.
Note that using this method is a sort of emergency stop so it will not save any new work you have done on the program/file.
Jan 06, 2009 | Disney Interactive Adventures in Typing...
I want to inslall ms word in my pc so how i can
first you need to have the installation disk for microsoft office. insert the disc and wait for it to autoload. just follow the instructions from there. if it won't auto run, go to my computer then go to the cd rom drive and look for setup.exe. that should run your installation window.
Nov 11, 2008 | Microsoft Office Professional 2007 Full...
HP Pavilion a1210n (ED895AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
