Question about SanDisk Sansa e250 MP3 Player
Installation how do i install my mp3 player. my computer does not recongnize my mp3. what do i do?
  • 8,596 Answers
If you do not have Vista, Use the volume + method listed below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Mp3 wont charge
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
Dec 28, 2009 | SanDisk Sansa e260 MP3 Player
I plug my sansa E200 in my computer and nothing pops up and its not im My Computer i just want to know what i have to do to put music on it???????????
Hello:
As i see the Computer Won't Recongnize it.
Well most likely its gonna be a Problem with the USB connection:
Try to inspect one of these:
  • Drivers Not Installed/Corrupted.
  • problem with USB Cord.
  • Problem with USB porte in PC
  • Probel with USB Plug in the Mp3 Player.
Good luck
Nov 04, 2009 | SanDisk Sansa e200 MP3 Player
Sansa updater does not recongnize e260
Make sure USB mode is MTP....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
Ipod 30GB
Unplug your ipod anyway & hope you don't lose data.
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Jul 31, 2008 | Apple iPod MA446LL/A MP3 Player
Not recongnizing
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 21, 2008 | RCA OPAL M4001 MP3 Player
Device driver problem
Hold in volume + and connect the goGear to computer - after continuing to hold the volume + for 10-30 seconds, Windows should reinstall the missing drivers
Apr 20, 2008 | Philips SA5125/37 MP3 Player
I have this problem too....
Mar 18, 2008 | SanDisk Sansa m230 MP3 Player
Opal 8gb
Hey, I have the same MP3 and I have Windows 98. I didn't try to install the CD that came with it. All you have to do is plug it into your USB port in the back.
Hope it works,
Shannon
Dec 25, 2007 | RCA OPAL M4001 MP3 Player
Multible ipods on one computer
Do what you did to get all 3 recongnized on your laptop on your main unit.
Aug 18, 2007 | Apple iPod MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
