Question about Samsung HLN617W 61" Rear Projection HDTV
Tv will not turn on
I press the on button and lite just blinks I have the same issue. I just replaced the bulb. Any thoughts?
  • Samsung Master
  • 8,617 Answers
Either the ballast or the DM. It will need to be trouble shooted to be sure. do you have the service manual for your set? You will need it if you plan on diagnosing the problem yourself. If you would like a link to purchase the factory service manual let me know
Posted on May 21, 2008
My left turn signal recently stopped working. Before ceasing to work, the turn signal (just the left) would blink very rapidly (machine gun speed).
sounds like one of light bulbs was malfunctioning and caused the flasher unit to blink rapidly and iy burned out. Replace front and rear turn lite bulbs and see if flasher flashes. if not check fuse and replace fuse. If fuse okay replace flasher unit. Good luck
Jul 08, 2016 | 1997 Plymouth Voyager
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lamp or Power issue Panasonic PT56lcz70
I would think that the fact that when you held the power button in for a long time that would give you a hint! If the power button is making a poor contact there will be a small surge of power and some parts of the internal circuits will respond(indicator lights, for example). Try REPLACING THE ON/OFF BUTTON.
Jan 22, 2013 | Panasonic PT-56LCZ70 56" HDTV
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I need instructions for the zenith universal remote 3201 for a new Panasonic LCD TV
If you have a manual for remote and you try all codes for your model and it didn't work, you may try for automatic search. First turn on TV, and point the remote toward the TV. You press: SETUP and hold, and press button for device: TV, lite is on, then you release all button and press again SETUP, just once, the lite is blinking, now press the power button on a few seconds. When your tv is turned off, you press button TV. Press button for power and it will turn on your tv. Try other commands on your remote, if everything is working that's it, if not do procedure again. Hope this was helpful, if not, ask more. By!!!
Nov 03, 2009 | Zenith ZN-501S Remote Control
Bulb burnt out and was replaced but lamp lite still blinks and no
You have one of the following issues.Be sure to check that the lamp door is properly attached. This can cause the the lamp light to go on.
1. Bad thermal sensor for the lamp.
2. Bad ballast.
3. bad supply voltage from power supply.
Apr 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Samsung HLN617W 61" Rear Projection HDTV Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
