Polaroid PhotoMax PDC 3030 Digital Camera Logo
Posted on May 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disc I cant find the disc for my camera, can you tell me where I can purchase one from Many thanks Trish
Anonymous
Level 3:
Guru:
  • Master 1,463 Answers
  • Posted on May 20, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1463
Questions
0
Helped
964913
Points
3853
Hi
you can get the driver from here
Polaroid PDC 3030 Driver Summary
riz.
  • Anonymous Jan 10, 2012
    I have the same problem as warmsmile but also do not have the USB lead. If I download the driver will it solve my problem & will any double ended USB lead work or would it be better to purchase a used identical camera with accessories? Thanks
Disc for samsong pl65
Contact Samsung online through customer support and technical support to see if you can purchase a disc or download the files. ebay has a vast amount of hardware and software, worth a shot.
I cannot finalize my disc on canon dc230 camcorder
my problem is u r tell me how do make video capture to computer because i will connect to camera and pc after canting sow no disc in my pc
Rear Disc brake is rubbingke
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Lost disc for FinePix S602Zoom no dealer in Quesnel
cant you need download the driver for the camera
and on vista the computer recognize the camera
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
1helpful
Drivers
Download here. This driver will work and I've tried it ;D, well, the top one at least.
[url]http://www.commentcamarche.net/pilotes/telechargement-95-pilote-vivicam-55[/url]
2answers
Cant Read Disc
I have had a similar problem with new Movie DVDs' - I don't think the DAV-S500 can handle the new Dual Layer DVDs.
I put the DVD in my laptop and it read it straight away with no probs............
Jamo
Trying to initalize cd
It's not your discs. BELIEVE ME!
We had the same problem, and had to exchange the camera.
New camera had the same problem.
We personally think there is a defect in this brand.
Too many people are having the same problem.
I called Canon and they blame JVC and Memorex which was recommended.
Called the disc manufacture and they blame Canon.
Canon did tell me not to fill up the disc and then try to finalize it.
Try a test disc and only film about 10mins of it and see if you can finalize it.
Make sure you are plugged into an outlet when trying to finalize.
We just hooked up our camera to a DVD recorder and transfered all images to a standard size disc.
Either they are not telling you the proper way to finalize in the manuel or this camera has a major defect.
At least we know we haven't lost any images by copying onto a full size disc.
Video not found after finalizing disc on Samsung SC-DC164 DVD Camcorder
Put it back in the Camera and see if it tells you the disc is finalized when it tries to format the disc. If it does then you know for sure it is finalized..
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
