Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral 23ADiW side by side fridge freezer
Freezer dept functioning ok but fridge isn't getting below 5C, even when freezer turned right up.
Any suggestions
  • browndour Jun 13, 2008
    I have the same issue. However, after following some website tips 1) check if thermastat is working - yes it is 2) check to see if vents/airways are blocked - yes they were and are now open/clear, 3) area under fridge is clean and vented - yes... I now have the add'l problem that now both the fridge and freezer are no longer cooling appropriately. The ice machine that was working yesterday is no longer filling/working and the freezer itself is warming up rather quickly. I don't want to pay for an unneeded service call if this is something I can fix.
  • 57 Answers
Is the back of the freezer section iced up?
If so you could have a defrost problem. All the cooling components are in the freezer section there is a damper controlled by a dial in the refrigerator that opens and closes.
If the damper is closed it will not allow air into refrigerator section. It is seperate from the Thermostat.
If the damer is opened to much you can start freezing food in the refrigerator section.
If there is ice on the back wall of the freezer section. It is not defrosting. There are 3 parts in the defrost process. The thermination stat, the heater, and the defrost timer or it's a timer on the electronic board behind the metal plate on the back of the refrigerator.
Good Luck
Posted on May 20, 2008
Admiral side by side, freezer working, fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
My Admiral HMG241777 is not cold, freezer is okay.
Most reasons for fresh food section not cold but freezer ok is a defrost problem or evaporator fan not functioning. Look at the back of the freezer, if it is covered by frost it is not defrosting and will not circulate air properly.
Jun 22, 2010 | Admiral 26 cu. ft. Side-By-Side...
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
158 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
