Question about Zanussi F1045W Front Load Washer
F1045w spin prob
Hope i have better luck on here than previous! my machines spin cycle is clicking off as soon as it clicks on
when the spin cycle starts the drum spins up but as soon as it begins you can here the relay/ solenoid click back off and the motor slows back to off - does this maybe 3 times then that is cycle complete, no problems draining etc, filter clear all hoses and water ok
  • 1 more comment
  • jim 1966 Jun 01, 2008
    washer clicking off when on spin cycle
  • Anonymous Jun 10, 2008
    Same problem
  • grahamawrigh Jul 09, 2008
    Tries to spin - attempts two or three times and clicks off. Affected fast spin first and would do a slow spin but now the same on both spin cycles.
  • 42 Answers
Unfortunately that sounds like your timer is faulty.......in Ireland a timer is now costing approx €100-€150 euro so its not worth replacing outside of warranty
Posted on Mar 31, 2009
My Hoover top-loading 550MB 5.5Kg washing machine is clicking only as it progresses through the wash cycle and not agitating the clothes. Previously the spin cycle hasn't worked and I've checked the...
Your description leads me to believe your problem is with the agitator DAWGS. Remove your agitator and check inside the agitator to see if one or more are broken off. If they brake your agitator won't work as it should. Good Luck Friend.
Feb 16, 2018 | Washing Machines
Zunussi F1045W. Horrible noise from the drum when spinning. I think the bearings are ok and the 2 top springs are intact and on. Any ideas? Steve
Hey dude ..... the first opinion may be your problem, the drum is suspended purely with bearings fixed at the rear. If you truely believe its ok - remove the belt & run the machine perhaps the motor bearings is the only other suspect.
At low revs its difficult to ascertain if a beraings faulty or not.. turn the drum by hand and try listen to & compare for noises.
hope you have some luck...
Jul 08, 2011 | Zanussi F1045W Front Load Washer
The washer off and on on the rinse and spin
there prob coins blocking drain pipe and cant 100% empty.
i had it with mine
Apr 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Spin cycle
Most likely your drum bearings are worn out. This is a major repair.
You may be better off replacing the machine.
Ash
Oct 22, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Noisy spin cycle
Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
Dec 15, 2007 | Zanussi F1045W Front Load Washer
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
204 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
