Question about Nokia N73 Cellular Phone
Answer phone problem
When i switch my phone on it says i have an answer message on line one,when i select the listen option there's nothing there but the answer phone message icon stays on all the time how do i delete it off and acess the message
Solution
Posted on Aug 10, 2008
Solution
BT 4500 cant answer messages from base only phone help please
Master unit has On/Off answer button. Select option you require.
The extension units do not have a message facility.
Nov 12, 2014 | BT 4500 Cordless Phone - DECT - Satin...
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How to listen to messages
The EV2625 isn't an answering machine. To listen to your messages, refer to the documentation for whatever answering machine or voicemail system you have on your phone line.
If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Feb 27, 2014 | Vtech EV2625 Cordless Phone
I am having problem with leaving messages. Everytime someone try to leave msg..voicemail say your memory is full, please hangup..but there were no messages in there..I also turned the machine off to see if...
Deleting messages (memory may be full).
Verify you do not have old messages on the the system. After the system plays all new messages, press Play/Stop again or from the handset Select 2:Play.If you find messages, delete them during or after they play.
After you listen to your messages, the voice message icon turns off. If it doesn't or if you can not receive messages, you should try to reset it: With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Make sure the Record Time is not set to Announce Only.
Jun 20, 2011 | Uniden DECT 6.0 Cordless Phone
How do I change the answering machine message?
Do you use a message service? ( Do you call a number to retreive your messages?) If so, call the number and listen to the options on the menu. Choose the option regarding your message and you will have an option to record a new message.
Dec 20, 2010 | Panasonic KX TGA106 Phone
Need to cancel answering machine message. Please help
Press1 and hold it or call your own number. When you hear your message press wither # or * and go to message settings.
(It is usually #)
Then listen to your options and select the one you want to change your greetings.
Aug 06, 2010 | Cell Phones
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Carl
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
