Question about Sony KDF-E60A20 60 in. LCD HDTV
Kdf-e60a20 My sony 60" shut off and I have the power LED blinking 4 times. The unit will turn on but will shut down again afert 10 seconds.
  • marcia_393 Jul 08, 2008
    Six blinking red lights onmy Sony KDF-E60A20 60" TV. TV will not turn on now. I read here about the thermal fuse. I ordered one and have it now. How do I change it? Please help!
    Problem Solver:
  • 7 Answers
Do a google, Sony 4 red blinking lights, there is lots to read. Read it all. We had 6 blinking lights and it was at $20 thermal fuse that we reinstalled ourselves and saved lots. It was past warranty. You can also put a message out on the blogs. But do your homework, it's worth it. Good Luck, Kim
Posted on May 22, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
The unit turns on and off every 40 sec. or so. I have turned the unit off and on and I get a red light blicking 5 times on and off. this happened about 4 to 6 mo. ago and it is happening again...
Below info are related to Sony KDF-E60A20 lcd projection tv.
5 times red light blinking indicates problem with lamp drive circuit (ballast supply board) that is not producing high voltage for lamp to generate high bright white light.
Check/ replace ballast supply board in above mode tv to solve this problem.
If you tv model is different, let me know to provide you related info.
Thanks
Jan 17, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-e60a20 Problem with the tv turning off and on every 15 seconds
go into customer setting and check see that the no signal shut down is tuned of SOny has a problem with that setting and it turns off even with a signal
Sep 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Looked and the thermal fuse is not broken
check again thermal fuse that you replace maybe wattage is not enough. there a lot of protection in that circuit.
May 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
260 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
