Question about Rockford Fosgate Punch Stage P110 S4 Car Subwoofer
Punch p1 10" not working
Yesterday outta nowhere one of my subs just stopped workin completley but the other one was fine. I pulled her out today and disconnected the wire from the sub and the port that runs to the clips that runs wire to the amp, and put new ends on the side connecting to the port, then put the wires back to the sub. Worked long enough for me to feel good about fixing it, then stopped working again. Any help? Speaker is not busted i checked it up and over and my testers says theres power running to the port connection inside the box.
I had the same issue with 2 Punch p1's. The wire stripping was most likely cut where the wires are saddled against 2 bare metal "C" shaped tabs before going toward the cone and coil. This was causing the wire to ground out. I cut both wires and **** connected them and bypassed the factory bracket. They work fine now. This is a poor desogn from Rockford and I can see where it might happen numerous times.
Posted on Oct 20, 2008
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
Belts
You have a componant that is driven by the belt that is frozen solid and will not let the engine crank.Take the belt back of and turn all the pullys by hand to find the frozen one.
Feb 18, 2010 | 1996 Ford Mustang
My punch 550.2 amplifier's thermal light is turning on and off
well, hopefully the amplifier was wired correctly. But either way there are so many factors that can cause this problem... But the biggest one is the amplifier must have been sending some distortion to your subwoofers which a subwoofer can take a certain level of distortion and be fine but too much will blow any subwoofer even the highest of high end subs at a high volume... when your subs hit the point of blowing they will tend to just blow out one at a time... they don't just pop both right away. I'd say get the sub that isn't blown off off of the amp before it blows too... distortion is clipping most of the time... when you destroy the subs it will eventually work it's way to the next component in the system which is your amp and then you will be out an amplifier and subs. save yourself the headache.......
Dec 12, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
One subwoofer has stopped working
the voice coils could be damaged, check for burns on the connections
Dec 03, 2009 | Rockford Fosgate Punch® P2D412 Car...
Rockford 12'' P2 sub, stopped workin.
It sounds like you have a bad voice coil in the speaker.You can have the speaker rebuilt, but it is very expensive. People usualy only have very high end home speakers rebuilt, because then it is worth the cost. Hope this helped.
Aug 18, 2009 | Car Audio & Video
My hx2 was workin fine until one of it went out..but the other seems to work fine still..is it because i hooked up wrong? i replace another one and the same side went out again..
Mine recently started doing this, the reason it is occuring is because there is a short in your amplifier that is drawing too much voltage and sending incorrect feed to your subwoofers. I wouldn't advise you to use your amp until it has been serviced. If you pull out your subwoofer from the box, you should smell the back of your sub, you should smell a crisp burnt smell from the voice coil internally being fried. If you want to learn more about your car stereo system you should check out www.bcae1.com.
Jun 11, 2009 | Rockford Fosgate Punch HX2 RFD1212 Car...
Left positive speaker input stopped working
try swapping over the rcas for instance if black is in r and red is in l then swap them so red is r and black is l
if that doesnt work try swapping the subs over to as you may have a faulty sub. if that doesnt work then check the fuses on the amp
still no joy then i would suggest taking your amp to your local car audio dealer and getting them to have a look at it
Hope this helps if so please dont forget to rate
best wishes
Upfront Audio
Apr 23, 2009 | Rockford Fosgate Punch® 450.2 Car Audio...
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
My amp is only pushing the left.
Swap the RCA inputs to see if the dead channel follows the RCA input.
Apr 19, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Rockford Fosgate Punch Stage P110 S4 Car Subwoofer Logo
366 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
