Question about Palm Treo 750 Smartphone
Beaming trying to get a beam from another phone sna it says to run the application??? How do i do this???
    Problem Solver:
  • 7 Answers
Go to settings, connections and run beam.
Posted on Jun 25, 2008
Hi my name is Larry I have a 1998 Pontiac sunfire & my problem that I have is I have low beam. But no high beam.
It's probably the switch , but testing to know for sure is alwasy a good idea .
Headlamps Inoperative - High Beams
Did you perform the Daytime Running Lamps (DRL) System Check?
YES - Go to Step 2
NO - Go to Daytime Running Lights (DRL) System Check
Disconnect the turn/hazard headlamp switch connector C1.
Connect a fused jumper between terminal B of the turn/hazard headlamp switch assembly harness connector C1 and ground.
Do the high beam headlamps operate?
YES - Go to Step 3
NO - Go to Step 4
Replace the turn/hazard headlamp switch assembly.
Did you complete the repair?
Repair the open in CKT 1200 between the turn/hazard headlamp switch assembly. Refer to Wiring Repairs in Wiring Systems.
Normal Result(s)
Abnormal Result(s)*
Turn the headlamp switch to the HEAD position.
Turn the headlamp dimmer switch to the LOW position.
The low beam headlamps are ON.
The high beam headlamps are OFF.
Headlamps Inoperative - Low Beams
Turn the headlamp switch to the HIGH position.
The high beam headlamps are ON.
The high beam indicator is ON.
The low beam headlamps are OFF.
Turn the headlamp switch OFF.
Turn the ignition to ON.
Disengage the parking brake.
The high beam headlamps come ON at a reduced intensity in approximately 30 seconds.
Daytime Running Lamps (DRL) Inoperative, Headlamp Switch Operates Normally
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Jan 13, 2017 | 1998 Pontiac Sunfire
One low beam head lights will not work, high beam works though
check for a damaged wire for the low beam. Also wouldn't hurt to check the ground wire as the high beam will try and ground through the low beam but not visa verse
Dec 29, 2013 | 1997 Chevrolet Blazer
Daytime Running Lights Inoperative 2002 Toyota Camry
[Information] For a 2002 Toyota Camry, the Daytime Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not burned out. If one burns out, there is a fair chance that the other would have burned out at the same time. Replace as necessary. In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function Switch on Turn Signals in "DRL" position, headlight switch off (repeating what the manual says -- it should be obvious that in the "DRL" position, the headlight switch should be off / do not have the switch positioned to "High Beam"), and the Parking Brake "off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box. there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3). Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues could be that the Multi-function Switch is broken or a connection / wire is broken. [Beyond the scope of this process.]
My problem was that the test configuration did not have the engine running and parking brake off - Step 1. Problem solved with much thought, repetitive tests on the vehicle and going back to the basics -- what does the Owner's Manual say and where are the applicable fuses and relays located?
Dec 30, 2011 | 2002 Toyota Camry
2005 Ford Focus ZX3 SES, the blue high beam indicator in the dash comes on with low beams, and goes off with high beams. The indicator is on at the wrong time! I have tried the following: The turn signal...
It sounds like you are confused about how your headlamp system is supposed to work. The DRL does not run on the High beam circuit, it runs on the low beam circuit. The fog lamps are supposed operate with the park lamps and also with the low beams, not the high beams. From your description, I would say that your system is operating as designed and you are having trouble telling High from Low. (Don't feel bad, that is why high beam indicators were invented in the first place.)
May 08, 2011 | 2005 Ford Focus
My 2000 Blazer low beam headlights won't come on .High beams, fog,running, turn signals all work fine.
Try changing the headlights....some headlight high beams will work even when the low beams dont
Aug 17, 2010 | 1995 Chevrolet Blazer
2001 Ford Focus - High beam / low beam problem with headlights
just replace the dimmer switch under the column its wore out on the low beam side
Jan 17, 2010 | 2005 Ford Focus
Low beam not working but high beam is-Pontiac Vibe 2005
I have heard it could be the Daylight Running Light module located under the dash above the brake pedal. The module controls both the daytime running lights and the low beam lights. The high beams are independent of this module.
I have the same problem. I am trying to buy a new module.
Jan 15, 2010 | 2006 Pontiac Vibe
1996 jeep cherokee sport headlight low beams wont work. high beams and everything else work, but no low beams.
try taking your tilt steering(steeringwheel) and check which setting its on if the tilt steering is all the way down click it up to the next setting and then try your low beams if that still doesn't work try it one more click up you might have a short or pinched wire in your wheel colum
Aug 17, 2009 | 1996 Jeep Cherokee
High beam headlight does not work properly
it more then likey a lose wire or bear one. run the line down. i think that the high beams run on diff. fuses. you can try that!
Jul 13, 2009 | Infiniti G35 Cars & Trucks
Palm Treo 750 Smartphone Logo
368 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
