Question about GE Refrigerators
Selected temp for freezer and refrigerator in not obtained. my milk and other foods are all spoiled. the meat from the freezer are not frozen. ice maker not making any more ice. I set the refrigerator at 37 degrees last night but the temp now is 45. freezer set at 0 degress last night but now its at 24.
    Scholar:
  • 57 Answers
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up.
If it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
Hope this helps
Posted on May 20, 2008
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
Why do I need a separate temperature control for my fridge and freezer?
For the same reason you want them at different temps.
Older single controls would affect both temperatures. So if you wanted the ice cream to be a little softer, the milk spoiled. If you wanted the meat to stay frozen longer, the lettuce got iced.
Aug 22, 2014 | Max-Fridge Refrigerators
Hi my side by side wards refrigerator and freezer doesnt always get cold enough some times it will make ice and keep milk cold and other times wont make anything cold. it spoils milk one day and next day...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
Kirkland signature rifrig..freezer is icing up...everythig frozen solid...lower refrig only cool...milk souring in several days
that why it is called freezer, it supposed to frozen your food and make some ice on it, what is not supposed to build some ice is the allside of your freezer, but the food and others stuff should be frozen
Nov 06, 2009 | Refrigerators
Our freezer and fridge just quit working too
It sounds like the thermocouple has gone faulty. This is part of your temperature control system. Best to have it checked out by an appliance repairman. Good luck, Dana
Sep 07, 2009 | Refrigerators
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Amana ATB1935HR Top Freezer Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
