Question about Toshiba Satellite A105 Notebook
Tolshiba back lit problems
Any idea on the cost of getting the back lit replaced on this thing?
  • crichardson1 Jul 02, 2008
    I, too, have lighting problems. My screen is black so the computer is useless. I've asked at Office Depot and Staples and both companies suggest to send it to the main company for repair. I've had the computer 2 or 3 years to there's no warranty. I was told it would cost somewhere around $500 to $600. Ouch! Plus, where do you send it? What can I do in the mean time? I hate to purchase another computer but.........
    Thanks for any help you can give me.
    Cheryl
    President:
  • 2,712 Answers
Should be under $100. Cost can vary from service center to service center
Posted on May 20, 2008
Kenmore microwave hood combination
If you have tried to reset the microwave oven by turning the mains power off and on without success then it is likely the display is faulty.
The only way to repair is replace the control panel board. This can cost a lot of money.
See this site to give you some idea. Best to contact a repair technician and get an idea of costs.
KENMORE ELITE Microwave Range Hood Controller Parts Model 72180839500
Aug 03, 2014 | Kenmore 1.4 cu. ft. Speedcook Microwave...
Delonghi gran dama display light out
This is a common problem fixed by replacing the control board. The part number is 5213214851 and costs around $135. It is a rather easy fix for someone who can take things apart and put them back together using basic tools.
Or, sending it to a reputable shop will cost about $40 for shipping each way, plus around 1.5 hours of labor, and maybe a small markup on ordering the part for you.
Apr 06, 2012 | DeLonghi Esclusivo Gran Dama EASM6600...
Have a Maytag gas dryer, model#:LDG7314AAE serial#:16068237QF, and the flame will not stay lit. It warms up ignites and then after 15 to 30 seconds it shuts off. It repeats the cycle but the flame stays...
Did you change the igniter, or glow coil as it is sometimes called? If it is orange in colour instead of white it needs to be replaced as it is not strong enough to ignite and stay lit. Hope this helps.
Nov 19, 2009 | Cars & Trucks
My 2001 automatic passat got flooded from water in battery well. All went inside mostly drivers side, carpets totally drenched. Since then gears not working, engine error sign lit and airbag fault sign...
Common with passat, there was a recall for water leaking in, the fresh air filter was installed with a paper type of seal. the new seal is better like a rubberised fiber braid. sounds like the electronics got wet and something burned out, might be looking at a costly replacement for the electronics. also check the drain for that area that usually gets clogged with debris-bits of leaves/sand/grit. check the cost or replacing elec.
Oct 25, 2009 | Volkswagen Passat Cars & Trucks
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
W300i speaker stopped working, other side cannot hear my voice
Hi, my w300i speaker (mike) stopped working, my voice cannot be heard on the other side, but, when I connect the handsfree, things become fine.
Seems, the internal mike has got a problem, please suggest a remedy?
is it mandatory to get the mike changed, something similar had happened a year back and that time, they had said, that since the mike is a part of the board, the entire circuit board needs to get replaced.
Any idea, how much the board (circuit) will cost in Mumbai, India?
Mar 25, 2009 | Sony Ericsson W300 Cellular Phone
No video on a 50H82 Toshiba Projection
If the screen is lit, then there is high voltage. If there is no video, and the screen is lit, then there is a loss of video. The fault can be anywhere along the main video path before it gets decoded in to the red, blue, and green compositions.
If the screen is not lit, most likely there is a high voltage failure, or there is a failure in the bias supply for the tubes.
When there is a loss of high voltage, this can be from any of the components in the high voltage area. Some of the main things that go defective are the flyback, high voltage multiplier, and various other small components.
Have you considered to replace the set with a good Plama or LCD set? This repair may end up being on the expensive side.
Jerry G.
Mar 10, 2008 | Toshiba 50H82 50" Rear Projection...
Panasonic CT-35HL43 36" TV has NO power
it could be the ac fuse gma 6.3 amp my ct-36hl43 did the same thing cost a dollar for the part 99 dollars laborer ragingbass@comcast.net
Sep 30, 2007 | Panasonic CT-36HL43 36" TV
TV turns off anf on
unplug-replug any/all connectors one at a time, including PCB edge connectors.
Sep 26, 2007 | Sony KDS-R50XBR1 50" HDTV
Toshiba Satellite A105 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
