Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch dishwasher sgs43a52gb
Spray arms not turning , found gear between small motor and diverter that deverts water between top and lower spray arms u/s. any idear where i can find parts and part numbers so i can replace
  • bernie910 Aug 31, 2008
    I have a Bosch exxcel dishwasher,don't know the serial number,the top spray arm,located under the top tray,does not turn.the water sprays out but it will not turn so doesn't clean very well.Any help or ideas will be most welcome,Bernie
  • 4 Answers
Try http://www.bshappliancecare.com/Bosch/boschspares.html
it's pretty flaky and I didn't work when I tried to download a manual for my SRS43A02GB/08, but the parts-lists do.
If you go to the 'Launch the spare parts eShop' and enter your model number (you only quote it partially above, so you then need to select the particular model), you can see the exploded parts diagram - click right-hand icon 'print all pages' to get a pdf of all the exploded diagrams. You can order from here too and they seem a lot cheaper than alternatives, but I haven't actually bought anything yet.
Posted on Jul 13, 2008
Bosch Classixx dishwasher around 5 years old. Started clicking regulary during cycles. Not much different although tablets weren't dissolving entirely. Now its clicking from back bottom left of the...
The Bosch may have a similar setup to the Meile where the main wash motor has a diverter which controls the water flow to the upper , then the centre, then the lower arms in sequence. When this sticks, the little drive motor "clicks" as it is trying to turn the diverter but cant. It will eventually fail. You may have to pull the motor out to check.
Feb 28, 2015 | Bosch Dishwashers
LG LDF6810ST dishwasher won't clean and spin arms properly
Check for a worn bushing washer on the lower arm. Also, make sure the arms are clean inside - they are propelled by reaction from the water jets spraying out, and clogs will prevent proper water flow through the jet orifices. Sometimes food debris will get through the pump and cause this problem. The diverter valve may also have trash inside clogging it and keeping from seating properly - this could account for both low pressure at the spray arm and water coming out of the lower rack when it should not.
Dec 02, 2013 | LG Dishwashers
Top Rack does not clean, Pump was just replaced. No Error codes. Heat is good, house water pressure is good, drain is good. I've cleaned the filter.
You do not say if the drain pump, the main motor, or the entire motor / sump assembly was replaced. If all the holes in the upper spray arms are clear, replace the VIRO motor. It is a small motor next to the main motor, and it switches a water valve to divert water to either the bottom spray arm or the top spray arm, intermittently. (normally about a 2 minute cycle, unless a "top rack only" setting is selected, etc.) The dishwasher has to be removed from the cabinets to replace it.
Jan 25, 2011 | LG Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Upper Spray arms not spraying
Took apart again and found the stepping motor which diverts the water from lower to upper spray arms to be burnt out. I was able to manually set the diverter to the correct position so the dishwasher works but I am waiting for new parts to properly repair the problem.
Oct 09, 2009 | LG LDF6810ST Stainless Steel Built-in...
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwaher does not clean, upper rack
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Hi I have a Kenmore model 13742k. The dishes in the upper tray are not getting cleaned. The upper spray arm is not circulating. I dissassembled the components from the base leading up to the spray arm...
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Mar 06, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Jun 15, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
637 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
