Question about Maytag Neptune MAH7500WH Front Load Washer
Grease spots on clothes
I have a Maytag Neptune MAH7500AWQ purchased in 2001. It is getting grease spots on my white and light colored clothes.
  • Anonymous Aug 16, 2008
    I've noticed it is only noticeable on whites & light colored clothes as well. Towels are very problematic because I use no bleaching or fabric softener products normally. I've been able to lessen it with spray stain removable products.
    I have not found any solutions on line.
  • Anonymous Mar 25, 2014
    leaves black grease spots on clothes
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
Posted on Nov 07, 2008
  • Grace LaPlante Sep 08, 2013
    We have the same problem...just noticed grease spots coming through after a wash cycle! Calling repair person tomorrow!
My clothes are coming out of my Neptune Maytag Washer with little black spots I always dry the washer and have no mold issues that I am aware of. What could be causing these spots?
Hello, unfortunately this was a common problem with that machine , the seal and bearing in the washer tub is worn and the grease is leaking out of the bearing and seal and is getting on your clothes. This is not a cheap repair, in fact I would recommend at this point to purchase a new or even a used washer from a shop that gives you a decent warranty.
Sep 28, 2015 | Maytag Neptune MAH5500B Front Load Washer
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
My maytag neptune washer is spotting my laundry - especially light colored towels with possibly an oil spot - about the size of a dime or sometimes quarter. I tried running a cleaning disc thru it twice ,...
f you use cold water wash and rinses regularly it may have an accumulation of un-dissolved detergent, dirt/grime and body oils stuck on the inside wall of the outer tub. When washing whites I assume that you are using Hot water and it could be causing some of the accumulation to break loose in small clumps and re-depositing on the clothes.
Jan 10, 2011 | Maytag Neptune Washer
I am getting little brown spots on my white clothing. Bleach seems to take them out. It just started happening.
sounds like a rear drum shaft seal may be leaking and getting either rust or brown grease spots on your clothes.If this the case,you should be able to see signs of water leakagein the back of the unit.Take the rear cover off and look in the area behind the large drum pulley.This problem also usually results in noisy operation eventually.The water would be getting into the tub bearing behind the seal.
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Grease stains from Maytag MAV7200AWW washer
HI! I just posted a question to "justask.com" and am having the exact same problem. I paid $9 for this answer and was happy to pay it because I now know what it is! From what I have been told, it is from the transmission in your washer and will cost at least $400 to fix it (that's just a ballpark figure... I have a Frigidaire and that was the figure I was given). So, basically, it would be more cost effective for you to purchase a new washer.
Apr 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Grease stains on dark clothing
Hi dredhill1
i have some good news for you, its n greas. what it is, is built up detergen between the tubs. its common on front loads. its due to to much detergen. waht i recomend to all my customers is not to sue more then 4 table spoons of detergen for a wash. now how to get rid of it, take some POWDERED dishwaher detergent and run a HOT cycle do this about 3 time and that should fix the problem. hope this helped .
brent
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
475 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
