Question about Intel Motherboard
Asus striker mobo does not want to complete post sli ready detected error. Also will no longer overclock with any acailable method
  • 2 more comments
  • catco May 22, 2008
    Still have the problem. Common post problem reported on interenet.
    Power up and post never completes. Setup screen nor video appears. If I power off and power on again 50% time it will complete post and then boot into windows.
    Also overclocking of asus striker fails any way you try even as low as 3%.
  • catco May 24, 2008
    This sysytem has been running overc;ocked from 3.67 to 2.8 8months flawlessly. No freezes!
    All of a sudden power problems started. When it first started I thought it was a "hiccup". It s was no hiccup. It gradually got worse.
    I note that others are reporting post problems for the striker extreme board.
    The ram RAM is a matched pair and I in fact had it replaced and reset bios to factory defaults. It failed to change anything.
    Looks like my system builder will get do a do-over. So many other report post problem I really beleive it id the MOBO.
    Any other suggestions would be appreciated.
    The PaulMo and worldvet for responding. Bless you!
    Jerry
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Hi Catco,
    The motherboard may be suitable for overclocking. However, your CPU may have barely passed the speed test for its rating with little or no headroom for an over clocker. Same goes for the Ram. This I think you probably already know.
    That being said:
    Do you have a matched pair of Ram?
    Are you overclocking with spread spectrum enabled?
    Try disabling spread spectrum where ever your are able.
    Worldvet
  • Glenn Rogers
    Do you still have this problem or have you resolved it?
    Worldvet
    Genius:
  • 1,027 Answers
If all else fails, reset the CMOS clock and ram to restore factory defaults and start again.
Posted on May 23, 2008
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Faster processor for Striker Extreme board
Pentium Extreme ED-965(3.73GHz, rev C1) is as high as you can go.
http://uk.asus.com/product.aspx?P_ID=G7JoxzAEXsQwDt7G There is the full CPU support list for this Mobo.
Jan 03, 2010 | ASUS Striker Extreme Motherboard
Powers up ,but no bios beep or video ,displays error 50 on pc analyzer
Accordin to manual: Error Code – 50
Phoenix (50)Display CPU type and speed.(Beep)=2-2-1-1.(50)Per- form LSL instruction test.[Beep]=none Custom chip set or custom platform.
The POST process stop detecting CPU.
M2N-E SLI use Award/Phoenix BIOS.
Oct 19, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I get a Post audio message on boot up/but no bootup
i have just thrown out 3 ASUS boards for various problems. they seem to last approx 18months before they die.
video output goes wrong, cpu socket errors, all sorts of problems and a rubbish tech support at ASUS does not help.
Feb 23, 2009 | ASUS P4P800-E Deluxe Motherboard
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
A8n32 sli + xp service pack 3
MIGHT WANT TO FORMAT THE HARD DRIVE.(XP SP2)RICHARDM69
Nov 06, 2008 | ASUS A8N-SLI Premium Motherboard
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
Blank Screen, no beeps, New Build
Hi Durmo, your troubles may be the SLI card. If you are using a single 8500GT make sure your SLI card is plugged into the motherboard as a single graphics card. See page 3-9 in your manual. If your 8500GT has dual out puts check both for display. Only one will show you display.
If you have this set correctly & you have tested your monitor on another system (& it is good) yet no display from the system than contact Asus. This board was make in 2007 & is warranted up to 2010. You can do this online or call Asus at 1-812-282-2787 M-F EST. Other countrys click the dropdown menu at Asus home page. http://www.asus.com/products.aspx?l1=3&l2=11&l3=473&model=1474&modelmenu=1
Post if you need more info.
Mike
Aug 19, 2008 | ASUS P5N-E SLI Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Intel Motherboard Logo
19 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
