Question about Barco Office Equipment & Supplies
RGB on Barco Reality Sim 6 diverge at edges...
Hi, I bought a Barco Reality Sim 6 on eBay for relatively cheap ($300) but am having some issues with it despite having found the manual in PDF form and having fiddled with the options I could find under the INSTALLATION and SERVICE MENUS. The biggest issue is that though I can achieve sharp focus in the center of the screen, the RGB signals seem to diverge towards the edges of the image. From far away, this makes the image seem blurry but within one foot of the screen it becomes evident that, say, a white line is actually being projected as red, green, and blue lines slightly misaligned vertically and horizontally. Now, I have been using the built-in test patterns to check the image and have not actually connected a signal....would this make any difference? Also, the manual lists one option under SERVICE that seems like it may fix my problem (electronic convergence) but it doesn't show up on my machine.
Any ideas would be appreciated as this could be one very nice projector if only it can be adjusted properly...
Should be possible to adjust the convergence having a projector this quality! Call Barco in Belgium and ask them!
Posted on Jun 06, 2008
Stator
Hi, Mikewarren1 spend the $10 to have it tested no oil in the world will help a charging problem and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2011+aprilia+scarabeo+300+special
Aug 23, 2012 | Aprilia Motorcycles
Bowed picture with color divergence
Hi, The Mitsubishi TV set you have uses two of the STK 392-570 convergence correction IC's. These IC's can be purchased from here http://www.mcminone.com/search.asp?keyword=stk392-570&btnSubmit.x=6&btnSubmit.y=7 These are the original Sanyo replacement type IC's. No aftermarket cheapo ones. Unfortunately this board that the IC's come on is part of the main Printed circuit boards. If one was available for a replacement, it would cost in the range of about 400 bucks. The way it sound that your TV set is intermittent, is that the IC's are not bad, but need to be simply re soldered. This happens a lot with this model number or set of convergence IC's. To tell you the truth, I have had to replace these types of convergence IC's very rarely. Mostly when the set come on with bad convergence and does not change. Find a friend or a neighbor who can solder, find the black STK392-570 IC's standing up against a large metal plate, turn over the printed circuit board and resolder all of the pins, just double check all of the solder points for solder bridges. Good Luck
Aug 02, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Can you replace the Bulb only instead of buying the whole unit, if so where do i get one from? many thanks
I don't believe that you can purchase this lamp as a bare bulb through official channels. It is an expensive lamp + projector and buying cheap copies is likely to be a risky business, definitely not supported by Barco. Prices seem to start at around £3500 GBP (ex VAT) or $5500 USD (ex TAX)
If you are in the UK, here are the 1st two suppliers I found
http://www.london-projectors.co.uk/projector-lamps.php?&brand=BARCO&model=SLM+G5+EXEC
http://www.jp-uk.co.uk/projector-lamps/barco/slm-g5-perf/barco-r9840740-projector-lamp.html
If you are in the US, again here are the 1st two.
http://www.amatteroffax.com/itempagey_invid_1366421801_d_premier-barco-oem-r98-40740-projector-lamp.html
http://www.advancedlamps.com/Barco-Genuine-OEM-R98-40740-Projector-Lamp?m1track=nextag&utm_source=nextag&utm_medium=cse&utm_campaign=export_feed&osCsid=bceddfd8470265866c6c1dd7172b765e#nextag
Given the fact that it is such an expensive lamp you should be able to negotiate a competitive price. I'd get on the phone to any potential supplier and ask them for their very best price rather than buying off the net.
Feb 15, 2011 | Barco SLM G5 DLP Projector
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Picture is warped (three colors diverge at edges
WS-55857 uses two STK-392-570 convergence IC's----you may have bad solder connections on them but what is more likely(I have seen this in sets that Mitsubishi made that use this chip) is that some of the pins are broken loose inside one or both of the chips.
Considering the labor to get the board out to resolder it, might as well just replace BOTH of the chips------Usually this repair can be done right in your home and takes about an hour.
If you are able to do it yourself you can buy both chips for less than 15 dollars on Ebay; if you need help I have complete step by step instructions for this repair that tells what you need and how to do the repair---if interested I can email them to you.
If you are not able to do the repair most shops charge 300-400 for this kind of repair; look in your area and if they say "needs to go to shop" keep looking; any good tech can do this repair right in your home.
Now is the slow time of year for TV repair shops so look around--I do this kind of repair here for 200-250 depending on the set --right in someones home! I have done hundreds of these sets.
If you need any help or would like the instructions reply to this comment here.
I do this for free here so if it helped you take a minute and give me a vote here.
SD TECH
Sep 02, 2009 | Mitsubishi WS-55857 55" Rear Projection...
I have a nokia 6500c and it has a piece of 3Gsim that made me use it with any network, now the sim-like card is cut and im unable to use my phone. What can I do please?
There are a few aftermarket sim wafer-thin adapter chips... you can get a new one on ebay.. look for "universal sim unlock" or turbo unlock... they are relatively cheap and simply slide in between your sim and the sim connectors... K
Jun 16, 2009 | Nokia 6500 Classic Cellular Phone
300/60 not compatiable!
Good ol' ebay has new and reman HP 60's black and color at rock bottom prices and they ship cheap. I haven't had good luck refilling HP 60 either, but search ebay for "HP60 inkjet cartridges" and you'll see many options. I bot 2 remanufactored ones and one was dead. The two cheap new ones I got were good. The " refill kit" I got was a disaster even after the seller refunded all my money. Good luck and happy shopping.
Mar 11, 2009 | HP DeskJet F4280 All In One Printer InkJet
Battery not detected
When you get this the battery is usually faulty, if you get one, try a replacement battery.
If it gives you same message with a replacement battery, then there is a broken circuit in the battery slot contacts.
Oct 19, 2008 | Dell Inspiron E1505 Notebook
Hi I have a blaupunkt car 300 radio cassette in my vauxhall and I have lost the code,I tried to get the code from a local repair shop he gave me 2 codes none of them worked and now the tries left are down...
look up eBay member acecar18 for any radio codes and other stuff it cost me £1.50 and was done from the serial number in less than 10 minutes, this guy knows his stuff and hes cheap!!!!
Mar 04, 2008 | Audio Players & Recorders
471 people viewed this question
Top Barco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
