Question about Dell Dimension 2400 PC Desktop
Dual monitors on my dell dimension 2400
I need to get dual monitors on my dell dimension 2400
  • Anonymous Mar 15, 2014
    connect to host computer for internet access
  • 3,940 Answers
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
Dell dimension 2400 keyboard and mouse and monitor not working
i think its a hardware issue so you should contact to dell care..
May 05, 2012 | Dell Dimension 2400 PC Desktop
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Aug 17, 2010 | Princeton Digital VL2018W Monitor
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
My Dell runs the RAM at single channel instead of dual.
if u have 4 ram slots check they are in the right slot'my old dell ram slots were 1.3.2.4.no you need ddr2 ram .yours are probably standard ram or u dont have daul channel ram slots.
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
Do I need to upgrade my video card before using a Dell 24 inch monitor with a Dell Dimension 2400
Technically, no.
However you probably won't be able to use your monitor's maximum resolution unless you do. However, if you don't you'll still be able to see the video. I recommend trying it without upgrading first and see if what you have currently supports your monitor's resolution. If you don't like the available resolutions, then you can upgrade.
Jun 25, 2009 | Dell Dimension 2400 PC Desktop
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
1,938 people viewed this question
Alun Cox
