Question about Brother HL 2140 Laser Printer
How to remove paper jam in brother hl-2140 - Brother HL 2140 Laser Printer
  • 25 Answers
Open the front door, remove the cartridge/drum...slowly slight the paper out. if it jams at the back ...do the same but rotate the fuser gear..if it jams on the tray not pull as it would cause the paper to break and sensors might get dmaged,
Posted on Sep 23, 2010
SOURCE:
Brother HL - 2150N Paper is jammed inside printer; how do I remove it ? URGENT - business printer... thank you!!
Open the front cover, remove the toner/drum cartridge.
Open the rear cover, look for a jam lever you can press down then remove the paper from the back.
If you try to pull the paper out through the front you can damage the gear system.
Use both hands to try and limit the possibility of tearing the paper.
Jun 14, 2011 | Brother HL 2140 Laser Printer
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
How could i fix paper jam on Brother HL-2140 Laser Printer?
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Jan 12, 2011 | Brother HL 2140 Laser Printer
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
I amusing a Brother HL-2140. Recently, the paper curls up and gets stuck in the tray, and will not move forward. I have cleared the pat several times, but the paper is stuck in the rollers, and it tears...
Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution center..how to clear paper jam
Good luck.
Thanks for using FixYa.
Aug 13, 2010 | Brother HL 2140 Laser Printer
Paper jam in brother laser printer Hl 2140 can help plse?
Here is the solution------
1. Open the Front cover of the printer. 2.Remove the cartridge and look inside the printer for jammed paper. 3.If any jammed paper found remove it. 4.Insert the cartridge again. 5.Closed the front cover.
It will help to solve your printer problem..
Jun 03, 2010 | Brother HL-2040 Laser Printer
Have a BROTHER HL2140. Paper jam: Can't remove drum unit & toner cartridge: Help
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Nov 08, 2009 | Brother HL 2140 Laser Printer
Error paper jam light still flashing after jammed paper has been removed and all covers are closed
Unpluging the printer for ten to fifteen minutes after removing the paper jam. This will clear all the memory in the printer and the error codes. If the error code still pops up contact the manufactor.
Aug 12, 2009 | Brother HL 2140 Laser Printer
Can we use tracing pager for print in brother HL-2140 printer model
consult your manual for maximum and minimum thickness of paper ... i suspect tracing paper will jam the printer
Jan 06, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
729 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
