Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Corrupt File System
When I try and back up my laptop, I get the following error: "The backup disk has a corrupted file system. Fix it by using the disk error checking tool or choose a different back up tool." I tried to use the restore files function...after rebooting, I get the same error message!?!?!?!?!?!?
  • MattWerner May 29, 2008
    Yep, that is correct...it was a formatting issue. Luckily, I took it to the guys at GeekSquad and they "fixed" it almost immediately. THANK YOU though for your help...you were correct!!
  • 23 Answers
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows.
So copy/paste the data you don't want to loose and then go to
My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
Posted on May 29, 2008
How to fix mySQL corrupt databases?
you should follow two steps:
Create an appropriately named database on the target machine
Load the file using the mysql command:
$ mysql -u [uname] -p[pass] [db_to_restore] < [backupfile.sql]
Have a look how you can restore your tut_backup.sql file to the Tutorials database.
$ mysql -u root -p Tutorials < tut_backup.sql
To restore compressed backup files you can do the following:
gunzip < [backupfile.sql.gz] ' mysql -u [uname] -p[pass] [dbname]
If you need to restore a database that already exists, you'll need to use mysqlimport
command. The syntax for mysqlimport is as follows:
mysqlimport -u [uname] -p[pass] [dbname] [backupfile.sql]
Or make use of Repair Toolbox for MySQL
Demo version is here-: http://www.sql.repairtoolbox.com/
Feb 08, 2015 | Microsoft SQL Server 2000 Standard Edition...
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
How to Restore XP Backup Data in Windows 8 OS?
Microsoft offers file transfer support.
Apr 25, 2014 | Computers & Internet
Error when recovery with vista
It is an effective solution for repair your damaged or deleted BKF files due to sudden system failure, virus attacks, media malfunction, backup interruption etc. Using this software, you can easily repair your BKF files. If you want to use the demo version of this software, then you can go on official site :- BKF File Recovery Tool
May 05, 2012 | Computers & Internet
A blue screen pops up when i turn on my computer statint that a problem has been detected and windows has shut down the code on the screen is 0x00000024-(0x00190203, 0x86f70008, 0xc0000102, 0x00000000)
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
Try the following:
- Enter to Recovery Console (http://support.microsoft.com/kb/307654/en-us)
- Run the command: CHKDSK C: /F
- Restart the computer
If you are unable to load Windows there is a chance that your partition is corrupt beyond repair. In that case, you need to reformat the partition to be able to use it again.
Before this, and if you do not have a backup, you should consult a technician because you can try installing the faulty disk in another PC to try to recover the data.
Mar 22, 2011 | Computers & Internet
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
My computer says I'm missing esapp.dll & ltdis10n.dll. How do I fix that?
This may be due some or all of the following reason: Corrupt file-system, corrupt registry entry, improper/incomplete device driver installation or software installation or may be due to a virus infection.
Make sure you have a backup of important files/photos/documents in your system.
Try repairing you file-system using check disk utility that comes with windows. Repair your registry using a registry tool. Update the device driver or the application. esapp.dll & ltdis10n.dll belongs to Kodak Easy Share application. First completely remove the application and try reinstalling it. Have a full system virus scan with latest virus definition update.
Update your windows system with current patches and fixes using Windows Update utility.
All the best
Mar 06, 2010 | HP Computers & Internet
Not abe to boot up
YOUR WINDOWS FILE IS CORRUPT AND YOUR RECOVERY CD AND BACKUP WHICH IN HIDDEN IN THE SYSTEM IS ALSO CORRUPT . YOU HAVE TO INSTALL WINDOWS AGAIN IF YOU KNOW OTHER WISE CONTACT SERVICE CENTER FOR YOU PC.
Sep 29, 2009 | Computers & Internet
Dell Laptop Inspiron 6400 - "Stop Error Screen" appearing
There are two ways,you might be able to fix it
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware).
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
825 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
