Proview PS 709 17 in.CRT Conventional Monitor Logo
Posted on Sep 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Proview ps707a and I can't adjust the screen or set it to default screen adjustments. I can't view the entire screen and its a wierd shape. What to do?
Anonymous
Level 3:
President:
  • Master 1,851 Answers
  • Posted on Sep 22, 2010
Anonymous
Master
Level 3:
President:
Answers
1851
Questions
Helped
458390
Points
5616
There are buttons on the screen for setting the shape, the size, the position and many others settings. I suggest to get to factory defaults with these buttons and then try to make any adjustments. In case you have problem with these buttons post me back to locate them for you from the user manual.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • 1 more comment
  • asteffen987 Dec 15, 2010
    I am having a similar problem. I've tried to use the buttons on the front of it to adjust it. But the width will not expand beyond 1/3 of the screen - so everything is terribly tall and skinny. I've tried a dozen or so combinations - but none of them seems to allow for a reset to factory defaults.
  • Anonymous Dec 15, 2010
    These buttons are for small corrections for the screen. Since you have missing 2/3 of the screen I suggest you to set your monitor's resolution and refresh rate one step down (at least). Click on start - settings - control panel - screen - settings (the resolution at this panel must NOT exceed 1024X768 for this specific screen) - for advanced users - screen - refresh rate (set it at 50 or 60 Hertz) and click apply - ok. Check the results. The problem must be gone.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
    Okay, that seemed to be helping. Esp the changing the refresh rate - unfortunately, I believe I have bigger problems. I looked up and saw smoke coming out of the monitor as I was working on it. So now it is cooling off on the fire escape. Next stop, dumpster.
Can't view entire e-mail on screen, too large
Go to control panel and adjust the settings for ease of use or adjust size of screen at bottom of screen . many ways to change it depends on your windows and computer
I have a old CRT Proview monitor. It has developed a problem of exceeding display sidways, means the display from left and right side of screen goes beyond, I have adjust manually left and right to view...
Well, if the adjustment buttons don't work, then probably the control unit in the monitor is broken, or a key is stuck. If the control unit needs servicing, I doubt if it's feasible to have it repaired, given the fact that it's an old monitor and new or used nice slim LCD monitors can be purchased cheaply nowadays.
Tv to dark but unable to find remote control. Can it be adjusted manually?
There should be a button labeled as "menu" press it and then select either picture or screen adjustment, go to brightness and set it higher for a lighter image
Blurry screen on proview tft monitor
Try to adjust the picture adjustment.Like the contrast and brightness
I have a new flat screen monitor, thats oblong in shape and my eyes are going nuts because its all stretched out and i want it square looking.how can i change it?
This is common with wide screens and the screen resolution needs to be adjusted to keep the correct aspect ratio.
My method, open MS Word - new document then Click on Insert - Picture - Autoshape and select a circle and place this shape in the document. Then if you wish to make the shape larger, then hold down the Shift key and drag the corner box to make the shape larger.
NOTE by holding down the Shift key, the circle will keep its shape and not distort.
Now Click on Control panel - Display - Settings and adjust the screen resolution and then view the Word doc with the circle, if it is not a perfect circle then, adjust the screen resolution again until you see a perfect circle. I suggest you start at the highest resolution that suits you and work down.
I cannot adjust my 15# inches suns star monitor to its default mode
Vista: hit the flag/start then control panel, make sure you see control panel home not classic view. Hit adjust screen resolution under Appearance and Personalization. Adjust the little arrow thing and click apply until it looks right. Mine is 1024 by 768 pixels. Mine is also a 15 inch so this setting should work for you.
XP: follow similar steps from vista names and views may be a little different but the command link is similar.
2answers
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
How to reset all adjustment to factory default on KV36FS10?
go to service mode, press 5 & 0 on remote, all data will intilize and default data will be written now save data on memory by pressing mute & 0 on remote.
you need to adjust horizontal, vertical and pin geomatry adjustments after above default data setting procedure to view correct aspect picture ratio on screen.
Top Proview Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
