Question about Car Audio & Video
Audio noise while car is on no prob in past
I have had my car stereo for about 4 years and had never had a problem with it before. Now when I'm driving down the road my stereo will make a loud thump thru all of the speakers. I have 2 amps attached the newest one is about a year old, but this noise is thru all of the speakers. I checked the connection at the battery and to the amps and they are all fine. What could be causing this loud noise to come across? It makes me and everyone just in the car when it does it and I have no way of knowing when it will do it next. Sometimes it's fine and sometimes I just have to switch it to standby.
  • 57 Answers
I've had that same problem before. What was happening is one of my amps safety cut off usually a built in surge protector basically, was coming on thus the loud thump. Most of the time when it comes on the amp goes off. Could be a power issue as well. Have your alternator checked too. Once your car is started it is run by your altenator so it could not being supply enough power. I fixed my problem by adding two 1 fared capacitor, one for each amp I was running.
Posted on May 21, 2008
Does an audiobahn A2801Q throw 1000 watts
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • Mar 15, 2011 | AudioBahn A2801Q Car Audio Amplifier
    I dont know how many watts it is
    4 Ohm Stereo Power (RMS): 250W X 2
    4 Ohm Mono Power (RMS): 850W X 1
    2 Ohm Stereo Power (RMS): 450W X 2
    Signal-to-noise ratio: 100 dB
    Frequency Response: 5 Hz - 50 KHz
    Total Harmonic Distortion: 0.05%
    Input Sensitivity: 200mV-4V
    Length: 16.93"
    Width: 11.66"
    Height: 2.37"
    Continuously variable 0 - 18dB Bass Boost
    Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
    Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
    Best Buy installed new stereo in my 1996 Z3 - Now my stereo stops playing when I put the drivers side window down. My car recently started blowing a fuse. Help...it's been almost 4 years since I had the...
    :o( you're going to have to pull the radio out to see what they did. They probably added a wire to an inappropriate circuit to power the new radio or amp. I will paste your factory wiring colors below. If you now have an extra wire, that is the likely culprit. Trace it to see where they hooked it in. If it isn't going to the the fuse box and using an extra slot, make it so by connecting it to the cold side of the fuse and put an approprite size fuse in. To determine the fuse size to use, you can compare the wire gage to other cold side wires and use a fuse the same size as you see being used for similar gage wires. Let me know if you have more questions.
    1996 BMW Z3 Car Stereo Installation Diagram
    Car Radio Battery Constant 12v+ Wire: Red/White
    Car Radio Accessory Switched 12v+ Wire: Violet/White
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Gray/Red
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: White
    Car Stereo Amp Trigger Wire: White
    Car Stereo Amplifier Location: Passenger Kick Panel
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Yellow/Red
    Left Front Speaker Negative Wire (-): Yellow/Brown
    Right Front Speaker Positive Wire (+): Brown/Black
    Right Front Speaker Negative Wire (-): Blue/Brown
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Blue/Black
    Left Rear Speaker Negative Wire (-): Yellow/Brown
    Right Rear Speaker Positive Wire (+): Blue/Violet
    Right Rear Speaker Negative Wire (-): Blue/Brown
    Oct 26, 2010 | 1996 BMW Z3 Roadster
    Need a wiring diagram for the stock stereo system in order to install after market unit
    2007 Saturn Vue Car Radio Wiring Diagram
    Car Radio Accessory Switched 12v+ Wire: Dark Green
    Car Radio Ground Wire: Black/White
    Car Radio Illumination Wire: N/A
    Car Stereo Dimmer Wire: Light N/A
    Car Stereo Amplifier Location: N/A
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Left Rear Speaker Positive Wire (+): Brown
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    Good luck and Happy New years.
    Jan 04, 2010 | 2007 Saturn VUE FWD 4
    I have a 4 month old Dell Studio 1535 laptop, with audio problems
    Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
    Check the microphone and try to play music again.
    Please post back
    Good luck.
    Oct 02, 2009 | Dell Studio 1535 Notebook
    How many watts dose a concept cc-752L amp have ?
    4 Ohm Stereo Power (RMS): 75W X 2
    4 Ohm Bridged Power (RMS): 250W X 1
    2 Ohm Stereo Power (RMS): 125W X 2
    Sep 26, 2009 | Concept (CC752L) Car Audio Amplifier
    Static noise from car stereo
    change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
    thats all i can think about
    hope it works
    Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
