Question about HP Office Equipment & Supplies
Which usb cable do i need to connect my new 6980 printer to my pc
    Genius:
  • 1,447 Answers
You will need a Highspeed 2.0 A/B usb cable or a usb printer cable.
Hope this help, pls rate as fixya, thanks!!
Posted on May 20, 2008
Where to find driver for HP Deskjet 6988 printer in Windows 7 ?
You'll find any available drivers for the HP Deskjet 6988 on the support page for the 6980 series printers: https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-6980-printer-series/468002/model/3422864 .
The Windows 7 driver should be found by Windows Update when you connect the printer with a USB cable. If you are using the printer in a network, you need to manually add a printer (using the wizard) from the Printers and Devices Control Panel. Start this after you have the printer connected to your router or switch. See https://support.hp.com/us-en/document/c01796879 and expand the section for Wireless or Wired Connection (Windows 7, Vista).
I hope this helps.
Apr 14, 2017 | HP Office Equipment & Supplies
I have an Acer 5321-1805 laptop and installed a Medalink version 3.0+ class2 dongle, but I can't print on my hp 6980 deskjet printer which also has a dongle installed. It pairs, but the printer driver...
Welcome to FixYa.
You have to configure the Bluetooth settings of the printer first. I assume that you have the HP bluetooth dongle on your printer.
Configure Bluetooth settings
You will need a USB cable to configure the Bluetooth settings
  • Connect a USB cable from your computer to the rear USB port on the printer.
  • Open the printer Toolbox.
  • Click the Configure Bluetooth Settings tab.
  • Configure the settings you want, and then click Apply
    Keep me posted.
Sep 09, 2011 | Computers & Internet
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
Deskjet 6980 with wireless printing. can't get it to print wireless. shows offline
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
http://www.fixya.com/support/t7236576-not_printing
Dec 02, 2010 | HP Office Equipment & Supplies
HP Deskjet 6980 series - randomly printing out the Report Page throughout the day. Drivers updated, cables reset (connected via USB) but the issue still persists.
pls uninstall the printer driver from your pc, remove the usb core, turn off your printer and shut down your pc for about 10 min. then put on your pc reinstall your printer driver, if you have another usb cable change
Aug 04, 2009 | HP Deskjet 6980 InkJet Photo Printer
Hp deskjet 6980 - green light on key beside the lock
it can be the problem of cartridges got faulrty so that needs replacement any of the two cartridge can be faulty. or the wire less connection issue.in that caee just conmnect the printer with a usb wire and check out.if same problem in connecting wire then its cartridge issue foir sure.
Feb 26, 2009 | HP Deskjet 6980 InkJet Printer
Disgusting breakdown or "Lost connection" of our brandnew Printer!
I bought a lexmark z1380 over the weekend.
I found that if you disconnect the usb momentarily for any reason the printer will immediately send out a jamming signal over usb regardless of whether on or off and the power button, (this jams whatever computer I plug the usb into after) only solution is pull power cord (or unplug) on the printer and replace whereupon it works ok then.
Feb 17, 2008 | Lexmark X1270 All-In-One InkJet Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
