Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Object between rotation and stationary drums
Underwire from a bra worked its way between the drums making quite a racket during spin cycles. Need best way to access this space to remove the wire, hopefully with out major disassembly on one month old unit
Solved the problem - removed the back piece of the washer to give relatively easy access to the drain hose to the pump. Removed the hose at the tub end and there was and end of the wire waiting to be pulled out ! Reattaching the hose is a bit of a fuss but the whole process was relatively simple . Other posts about blocked drains etc. pointed the way - thanks
Posted on May 22, 2008
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
During the spin the washer makes much more noise than it has in the past. There are also small chunks of hard plastic showing up in the clothes.
There may be an object that has gone through one of the holes of the spin basket, check to see, something like a bra underwire may have gone through and is rubbing on the inside of the tub
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Today, my washing machine started making a loud clicking noise during the spin cycle, or just as the spin cycle is starting up. The machine spins. It is not off balance. It is not the timer - we've had...
if the noise is in the drum the usual culprit is a rogue Bra underwire. look for it poking through any of the holes in the drum and pull it back if you can, otherwise it can be retrived through the heater location (requires some emgineering skill to remove and replace heater). if the noise is from the motor it will be a segment broken away from the armature . this requires a new motor.
Nov 20, 2010 | Washing Machines
My washer makes a click noise 2 times per rotation on the spin cycle. Even when empty, when i turn it the same noise happens.
typically a bra wire under the drum will cause this noise. a faulty motor will do it but with 10x more clicks . so look for rogue underwire.
Nov 09, 2010 | Washing Machines
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Thanks/Mike
Nov 06, 2007 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
61 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
