Question about Garmin StreetPilot 2720 GPS Receiver
Voice stopped working
Voice directions were working. Next day, they were not. Checked all audio settings and mute is not on.
  • 1 more comment
  • DJS22867 Jun 14, 2008
    Same here. Absolutely no sound whatsoever out of the blue.
  • columbus1 Jun 19, 2008
    I didn't find a volume wheel on the speaker. But it is now working for one of 2 reasons: Garmin sent me a new plug-in speaker (under warranty) and I downloaded a new voice. But where is the volume wheel?
  • dbroofing Jul 14, 2008
    My garmin 2720 street pilot is a very good unit but the voice prompts have stopped working completely Is there a fix for this or does the unit have to be sent in I have not taken any steps to correct this because I have not found any
    Scholar:
  • 174 Answers
Do you use the plug in adapter with the speaker in the plug?
Check it, there is a small volume wheel on it, probably sent it to zero whilst unplugging or plugging it....also check if the power plug is fully seated in the GPS
Posted on Jun 16, 2008
Lost audio
1. First, make sure that the sound is not checked to be muted.
2. Make sure that you have a text-to-speech (TTS) voice selected in the language menu.
3. When you press a function on the screen, do you hear a beep? If so, this indicates that the sound is not muted and that the audio circuits are working. If you don't hear any beeps when pressing a function on the screen AND there are no voice directions, then I would suspect a defective speaker. More information can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 24, 2014 | Garmin nuvi 255W GPS Receiver
THX navigation system in 2007 Lincoln MKX
Could be mute controls for the telephone. The voice for the Navigation is adjusted separately from the radio volume. If any work was done on the vehicle, like a battery disconnect, then radio controls may need to be reset.
You need to toggle through the Menu to things like screen brightness for the Navigation.
You also have a speed sensitive radio and the volume controls could be affected by these settings.
Jan 27, 2012 | Cars & Trucks
No audio on garminnuvi 255w
If you are not receiving any sound on your N?vi 2xx thefirst thing to check is that the sound is not muted. To ensure that your unitssound is not muted please perform the following: Turn the device on Press the Volume button on the 'Where To?', 'View Map'screen Ensure the Mute box is not 'checked' If the mute button is not 'ticked', you will need to changethe voice to ensure that the preset voice is not faulty: Turn the device on Touch the Tool icon Touch Settings Touch Language Touch the language voice next to Voice Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you arerunning the latest software which can be done by installing a program calledWebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the softwaresuccessfully installs.
Jan 24, 2011 | Garmin Nuvi 200w 255w 260w 270
I'm not getting verbal directions from my Garmin nuvi 260W. How can I fix this problem. A day ago it was working properly.
Jan 21, 2011 | Garmin nuvi 260W GPS Receiver
Voice stopped
Please see this link for more info on this problem:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Feb 14, 2010 | Garmin NUVI 360 GPS Receiver
Voice directions stopped working on my nuvi 350. Mute is not on, everything else works.
Make sure you have a voice selected in the voice set-up menu. Otherwise see this link:
- Jim
Feb 14, 2010 | Garmin GPS
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Audio directions
You must ensure that your volume is not on mute. You need to tap on where the words are, not on the map, until the volume slide bar pops up. You may have to tap in different places until it does. If your volume is set normally, you need to check on which voice you have picked. It's under the options. Pick a different voice and test out the directions.
Aug 09, 2008 | Tomtom GO 910 GPS Receiver
This may be a cold solder connection or mechanicaly defective component on the circuit board. There are many parts in that unit that can cause the described fault.
Jerry G.
May 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Mar 17, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Garmin StreetPilot 2720 GPS Receiver Logo
76 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
