Question about Hitachi Video Cameras
Formatting new disc
When I put a new disc into my digital HDD/DVD camcorder, it doesn't give me the option to format. The option is no longer in the settings menu, either. It's vanished off the face of the earth. (I've tried three new discs, two different makes. I am not touching the recording surface at all).
  • Envillestar May 21, 2008
    On reflection, probably correct .. my problem probably relates to 16.9 v 4.3 rather than formatting .. thanks
  • 203 Answers
A -r or sometimes a -rw doesn't need to be formated to work-there may be no problem at all-are you using the proper media for brand cam-sony + or - most others only use - check on door of cam
Posted on May 21, 2008
How to undo formatting of harddisk of sony Handycam Camcorder HDR-SR10E
If you once started formatting and change your mind while in process you only have one chance: Switch off your cam! If this doesn´t work, put off the battery. It´s the hard way and you might have damaged the last file but might have rescued the rest.
Best wishes
Aug 21, 2011 | Sony HDR-SR10E HDD Camcorder
How can I format a dvd
Hello and welcome to FixYa;
There is more than one way to do this; the method you want will depend on what type of computers/devices to how you want to format it;
One way is;
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
May 31, 2011 | Audio Players & Recorders
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Asking to format full disc
The simple trick is to put a disc into desktop DVD recorder. If Your DVD will be recognized, then copy all content to another DVD or camera. I've seen it before. Must work. Sincerely.
Sep 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Formatting the disk
Yes, the mini DVD-RW will work on this camera. When you insert the disk and power on the camcorder (with the mode on DISC), the camcorder will try to read the disk, and if it isn't formatted yet, the LCD display will offer you the option to format it (in VR or Video mode). Simply select and click to format the disk
May 07, 2009 | Samsung SC-DC173 DVD Camcorder
Canon dvd camcorder dc201
I am not sure if this will work but at least you could give it a chance..try to use ALCOHOL , DAEMON TOOLS or something similar to make a dvd image on your computer, then burn it on to an appropriate formatted dvd.
Aug 27, 2008 | JVC 20GB Everio GSeries HDD Digital...
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Jul 10, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Camcorder Problem
You need to do formatting on the disc when using it for the first time. Remember, formatting needs to be done by camcorder. If you used the disc before and formatted it on different machine - it won't work.
Jul 27, 2007 | Panasonic VDR-D300 DVD Camcorder
Format Error
First option would be to attempt to read the disk in another DVD player, for example on a PC. If that succeeds then transferring the data can be done via the PC. Another thing to try is to reset your Camcorder - refer to the manual to locate the switch and then try again. If neither works then re-formatting is probably the only answer. Always format the disks in the camcorder - not elsewhere.Good luck.
Jun 19, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Video Cameras Logo
148 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
