Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
On / Off switch
I am on my second Vacuum in two years and it getsd very limited use as it is only used down in the basement. BOTH had the same problem....the switch in the handle will not activate the on/off switch. When I look at the design I keep thinking, there has to be a better system??
Any ideas or any sort of adjustments or modifications I can make to eliminate this problem?
Not sure how you respond, but my e-mail address is: g,
Had the same problem and found that the interior switch was to stiff and the plastic activator would just pass over it. Solution was to pull the three screws that ho;d the activator switch, pull the interior switch and replace it. This is a lot easier than it sounds.
Posted on May 26, 2008
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Shark navigator will not turn on
Plugged in:
Try moving the cord around at the strain relief, where cord enters the vac, as internal wires may have broken.
Check brushes of electric motor, they may be worn down.
Check main switch continuity with a meter on ohms or buzzer.
But there could be a thermal fuse either in or on the motor, to avoid overheating damage and smoke signals!
Nov 20, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
Hi ! I have a Kenmore central vacuum (model # 34326), 3 inlet valves on different floors. the inlet valves on the second and third floors are already connected. I need to connect the inlet valve...
By your description it seems that You have telephone wire used. You only need two low voltage wires to complete the circuit to turn on the power to the central vacuum unit. The low voltage wires must be arranged so that when you insert the hose into any valve it closes the circuit. You will wire it as if the black and red are just one wire and the green and yellow are the other, they are actually doing exactly the same as if you only had two wires.
Mar 05, 2017 | Kenmore Vacuums
My central vac is in the basement, I am getting suction in the basement, but no suction on the main floor and the second floor. How do I know if somehting is blocking it or if there is a hole?
That means that you have a clog in the lines where the basement inlets are connected to. They can be tough to get out, you might need to call a professional.
Jan 10, 2010 | Electrolux Central Vacuum
Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Sep 28, 2009 | Electrolux Vacuums
Vacuum turns off after short amount of use
Check the vacuum for a clog somewhere, check any filters to see if they are dirty (i understand filters are going to be dirty after use, but i mean extreme dirty in this case), these are common things to look for when you have this problem
Aug 17, 2009 | Electrolux Guardian Bagged Canister Vacuum
Vacum bags
The vacuum that you have is over 10 years old. You can no longer get the bags directly from Bissell but if you call a authorized service center near you, they may still have bags that will fit your vac. So the answer to your question is yes....they use bags. Good luck!
Aug 03, 2009 | Bissell 3065 Power Partner Vacuum
Aerus Model 152C- vacuum doesn't run
it probably does think you have a full bag.make sure you have it cleaned out and has a bag in there or it might be the sensor for the vacuum and is not working properly. contact your nearest electrolux vac store.or you are not using proper bags.
Jun 28, 2009 | Electrolux Vacuums
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Feb 13, 2008 | Craftsman 17762 Wet/Dry Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
