Question about Mitsubishi VS-6043 60" Rear Projection Television
No picture or sound
I have a mitsubishi vs-6043 that when turned on the green light on power button stays on constant but can hear clicking noise on board in the back and speakers thump to clicking noise.the picture went out first then the sound.any help would be greatly appreciated. thanks
  • DeShark Nov 22, 2008
    I have the same problem.. set stopped showing a picture... just makes clicking sound and if the speakers are turned up it thumps through the speakers. Should I fix it or trash it?
Posted on Jan 21, 2009
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 20, 2008
MyMitsubishi VS-6043 Big screen TV just started to black out while we were watching it.I would turn it off and back on the picture would be there. Now the power light goes on but the screen is black. Is...
Not sure on that one. My local repair guru tells me the 6043's are constantly having problems. I've got one that I'm looking for board parts for, so if you end up not wanting to fix yours, I'd love to get your board set for some parts.
Nov 11, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
Same problem as nickatnight (no picture but clicking/poping noise)
Its possible that you could rectify the problem by changing the caps..but identifying the faulty ones is a bit of a pain and would require the services of a professional.. I could help you,but I m just too far away :)
Jul 17, 2008 | Mitsubishi VS-6043 60" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
No picture or sound,clicking in back and speakers thump to clicking noise
Tubes are messed up, to fix is REALLY expensive, trash it or part out what can still be used.
May 21, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
