Question about Dell Inspiron 9300 Notebook
NO POWER AT ALL
My DELL inspiron 9300 it doesn't turn ON?
I checked the AC cord and Battery nothing turns on, what else can I do.
  • FRANKROMERO May 20, 2008
    Thank you..........was helpful
  • abdoul88 Feb 19, 2009
    i can power my inspiron 9300 on battery but not on ac adaptori'd like to know if i can replace a component(protection for wrong power) instead of replacing the motherboard thank you!
  • 3,940 Answers
Remove the battery and unplug the AC adapter. With the AC adapter unplugged from the system, plug it into the wall, see if the power LED comes on. If it does, plug it into the system and see if it goes out. If the LED never comes on, or goes out when connected to the system, replace the AC adapter.
If the LED stays one, see if the system will power on and give any indications of power at all (Flashing Caps Lock, Scrool Lock, Num Lock LEDs) If no power indication with a good ac adapter connected, then the motherboard is the next item to replace.
Either item listed above can prevent the battery from charging. So the battery is the last item I'd replace unless the system turns on with the battery out of the system.
Posted on May 20, 2008
Dell Inspiron 9300. Problem occurs when I try to charge it. The screen says it can't determine the adapter type and the battery does not charge. I can wiggle the charger cable around at the connection to...
The same exact thing is happening to my Inspiron 9300. Did you get it repaired? After reading lots of forums, changing AC adaptors and ordering a new battery, I came to the conclusion that it is the plug on the laptop that is not working.
Nov 17, 2010 | Dell Inspiron 9300 Notebook
Computer dose not charge battery (replaced battery and same problem).. Computer works fine when pluged into DC power pack.. Computer is A Dell Inspiron 9300.
check if you are using correct Watt of ac adapter.if yes then download the latest BIOS update for your laptop. if all fails then replace the motherboard.
Oct 14, 2009 | Dell Inspiron 9300 Notebook
Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Apr 20, 2009 | Dell Inspiron 9300 Notebook
Cumputer comes for about 5 seconds and then turn back off
try this...take out battery for a couple of minutes..rub it with your hands...gets rid of static build up, sounds funny but it worked for me!
Apr 01, 2009 | Dell Inspiron 9300 PC Notebook
I have a Dell Inspiron 9300
if there is white line in the middle of the screen then first of all turn off the laptop and disconnect the ac adaptor and take out the battery and press and hold down the power button without the power cord and the battery for one minute and then turn on the computer with power cord and the battery and then check it out and still after that if u get it then check it out with the external monitor and if u get a good display in the external monitor then replace the lcd,but make sure that the screen is not broken from inside which u cannot touch and feel it.and if u get a good display in the external monitor then definately replace the lcd screen....good luck
thanks
Dec 27, 2008 | Compaq Presario M2000 Notebook
Power Problem
A very common problem with dell laptop's are the "batterys" I suggest calling dell and order a new battery for your labtop.
or
It may be that your psu "power supply unit" may be bad as well.
I hope this solves your problem
Nov 12, 2007 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 Notebook Logo
215 people viewed this question
Alun Cox
