Question about RCA D56W20 56" Rear Projection Television
Picture breaks up into several images. Seems to be on image for each color
  • RCA Master
  • 8,617 Answers
Convergence power supply is the problem Check the fuse FL231 that may correct the issue if not you will need a new convergence power supply board. Let me know if you need additional assistance.
Posted on May 21, 2008
Image is showing double on the screen. The entire screen's images are doubled and overlapping over themselves. Some color distortion obviously as well. Images basically aren't lining up. The red color...
On Rear Projection TVs there is a thing called "convergence" in which the color bands are lined up so that they can mix to make the colors that we see on the screen. When a TV of this type is moved or bumped around, or even near a source of electrical interference it can throw this out of alignment. Many TVs have options in their menus to set convergence.
I believe it is under Menu > Picture > Convergence I'm having trouble finding the exact process used for this, but it will be noted in your user guide as well.
If this does not resolve the issue you may need to purchase a convergence repair kit which requires a considerable amount of electrical knowledge and can take several hours to repair.
Feb 28, 2011 | Hitachi 65SWX20B 65" Rear Projection...
The picture wont appear, i get sound but the fan seems to be having trouble and th picture wont appear
A bad fan will keep the machine from producing an image but I suspect it is a bad color wheel. When color wheel fails, you may hear a high pitched whine and no image. No image can also be caused by a burned out lamp, bad ballast or power supply board. You can call 1-800-samsung to find the nearest service center.
Jun 16, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Sony KP-57WV600 different colored images red,
Ur convergence is dying,well be dead soon.These problems cause byconvergence.Blurry coloring,3D images or misaligns colors.Repair this must replaced 2 convergence ICS and all it resistors.The shop well cost U 300 for parts and labors.
Feb 09, 2010 | Sony KP-57WS500 57" Rear Projection...
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Canon A75 - viewfinder shows- purple distorted picture.
Its bad ccd imager in camera and this part will be replaced.
Canon will repair Free of Cost A75 camera as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A75 Digital Camera
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
RCA D56W20 56" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
