Back to:
Tags:
GE 46GW 948 46 in. Rear Projection Television
Will not turn on
posted by jms265 on May 20, 2008
I try to turn on the tv and it turns on for a second and turns off again then does ot 2 more times by itself . the tv is probably six years old can you help, please?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 21, 2008
Not Rated (0)
Slinteriors
Rank:Guru Guru
Rating: 88%, 2523 votes
most likely the flyback or another problem on the deflection circuits is shutting the set down
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on will not turn on:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
GE 46GW 948 46 in. Rear Projection...
Black stripe 1 inch and a haft wide appear at about 15...
I have a 6 year old Tv that will not power on at all. The...
The set turns on, but no picture or sound. using the...
jbjkbjbj
can u change to video functions manualy without remote? tv...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
