Question about Nokia 447Za Monitor
Received Nokia Monitor 447Za with out any info
I got this monitor from a friend and did not get any manuels or other disk to help me learn how to get the speakers and mic to work. Can you give me some sort of information on how to setup or fix my problem...Thanks Terry
  • massay76 Nov 27, 2008
    Do i need some cable to connect audio output and monitor input from right side of monitor ?
    Thanks
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Monitor Built in Speaker Problm
Hi shah. It is most likely that the speaker's transformer is burnt. If its under warranty then the showroom guys should fix it for you as its covered under warranty. Otherwise you will need to take it apart remove the old transformer and install a new one. I strongly advise "if you are not familiar with electricals then better take the assistance of a qualified engineer".
Regards,
Eagle338.
Posted on Feb 23, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Need manual for nokia 447za computer monitor
The adjustments you need to make are for the screen geometry. I haven't been able to locate a manual, so I can't tell you exactly how to access them. Usually there is a menu button that brings up the adjustments, and a couple more (usually marked + and -) to go through the choices and change the settings. A fourth button enters your choice. On some monitors there may be an adjustment knob/button combination. Press the knob to enter, and turn the knob left or right to adjust and choose.
Having said all that, what you want is called the pincushion setting. When set properly the image will be square. Improper settings cause the edges to bow in or out. Depending on how many adjustments your grandkid messed up, you may have to go through some other settings as well. Most monitors have adjustments for:
- vertical and horizontal position and size
- pincushion (adjust for the straightest top and bottom edges)
- trapezoid (also called keystone) which adjusts the top and bottom widths in opposite directions (adjust for the same length)
- parallelogram which adjusts the top and bottom positions in opposite directions (adjust so the sides are straight up and down)
There may a few other choices, but the previous ones have the most effect. There may be a choice in the menu to reset everything to midrange. If so, take it and then use the adjustments to fine-tune if necessary.
Posted on Feb 15, 2009
SOURCE: Nokia Monitor Multigraph 447Za - Speaker/Microphone Volume control not working
The electrical contact surfaces under the rubber buttons lose contact over time. I don't know if it's corrosion or some kind of build up. I fixed mine by disassembling the monitor, removing the button panel and cleaning the contacts with a pencil eraser. It works great now. The monitor is a real bear to take apart though. There are four hidden spring tabs on the sides of the bezel that are impossible to see. I groped with a very thin screwdriver blade and finally got them to release, but not without chipping some of the plastic.
Posted on Mar 08, 2009
How do I connect and get started with a dell core 2 duo desktop pc
You may NOT receive an instruction manuel with your computer.
You SHOULD have received a "quick setup" inside your computer box and your monitor box.
You may follow the pictures in that also.
Verify that you have a valid service provider/internet account
Connect your monitor to your desktop with the cords that should be with the monitor.
One goes in the back of the desktop
One goes to the monitor usually in the back or underneath the screen.
Be sure to look at the shape of the connectors or the colors and match colors to what is on back of the machine.
If you have a power cord connect that to back of the desktop
Plug the other into electrical outlet.
Press the round POWER button on the front of your desktop and it should turn on and start running and you would see the Windows icons on the screen.
Feb 07, 2015 | Dell Computers & Internet
I just got this eMachine E15Tr monitor and am trying to hook it up to my current pc. They are both hooked up correctly to my knowledge but whenever I turn on my pc the monitor waits to turn on. When it...
You have three components which could be faulty: Computer, cable and monitor. Replace them one by one until you find out which one is giving you trouble:
  1. Hook up a portable computer to the monitor, using the same cable
  2. Same thing, only with a friend's cable that is known to work
  3. Try using the cable to hook up a friend's computer and monitor
  4. Take your monitor to your friend's house and see whether it works there
  5. Try using any other source of image, check the back of your monitor to learn what else you can plug, other than a computer
Each combination you try will give you more information, until you have enough data to isolate the problem. It *could* be that your computer's resolution is not supported by the monitor, but I doubt it.
Feb 26, 2013 | Computers & Internet
HP L2208w monitor problem. First it worked good, but then suddenly this happened!! When i turn on my PC, monitor works fine, but after a while (sometimes a minute, sometimes a few seconds) it gets very...
If you can borrow a friend's or neighbor's monitor and hook it up,that would tell you if it is the monitor or the computer.If your friend's monitor does the same thing,it's the computer output or driver.If your friend's works fine,your monitor is bad.How old is your computer?Mine is only a year old but I have a 3 year hardware warranty.You may want to look into that if you aren't sure at least.Testing the monitor and computer as i suggested has a minor setback though.If there is a problem with the computer,it could also blow your friend's monitor.That most likely will not happen,but there is a slim chance.Ifit were me,I would check it as I suggested as I am that confident.I am just telling you things which POSSIBLY could happen so noone gets a surprise from my answers.I try to inform and educate by providing as much info as possible with every conceivable scenario.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg
Nov 28, 2010 | HP L2208W Monitor
Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Jan 27, 2010 | Watches
Driver for Vison EZX15F monitor
I have the Vison Monitor and looked all over for the driver and found nothing specific to the monitor. However, I have a dual boot on my pc with XP and Vista and it works well with both. My current driver specs for this monitor are below. I hope this helps:
Driver Provider: Microsoft
Driver Date: 6/6/2001
Driver Version: 5.1.2001.0
Digiral Signer:Microsoft Windows Component Publisher
Jun 19, 2009 | Computers & Internet
Regards,
Eagle338.
Feb 23, 2008 | Nokia 447Za Monitor
Graphics
Hi, It could be the monitor itself that is failing, have you tried plugging in another monitor?
Other than that the recovery disc may not have had the exact drivers for your monitor so you may be able to get the drivers or display adapter drivers for that monitor and install them.
Let me know how you go,
SeaJade
Nov 28, 2007 | E-Machines eMachines Desktop PC
Dec 12, 2006 | Nokia 447Za Monitor
Nokia 447Za Monitor Logo
51 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
