Question about Panasonic NN-T774SF Microwave Oven
The turntable in the microwave does not rotate.
    President:
  • 2,712 Answers
First you need to see if it is the motor that is bad. Usually you find the relay or switch that powers the motor and see if you have voltage.
Microwaves are better left to professionals. A novice could hurt themselves working on a microwave. I would suggest getting a repair man to fix it or buy a new microwave (whichever works out cheaper for you)
Posted on May 20, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Turntable
The turntable motor will need to be replaced, a common issue.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The turntable on my GE Spacemaker Microwave JVM1640BB does not turn.... I can turn it by hand, but does not turn during cooking.
HELLO.
THINGS NEEDED.
* screwdrivers
* replacement motor
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Hoping to help on more problems.
THANKS.
Sep 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Microwave turntable has stopped rotating can I fix it?
microwave turntable has stopped rotating can I fix it?
Mar 07, 2010 | Microwave Ovens
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Panasonic NN-T774SF Microwave Oven Logo
433 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
