Question about Toshiba 42H81 42" Rear Projection Television
Convergence I have a toshiba 50h82 is the convergence circuit board no. the same. and where can i get them. i have not aligned the circuits before is there a book with wiring diagrams and instruction on this procedure. with the price of gas and everything else going up it is hard to cut loose of extra money. so if possible i need to fix at home
  • rediflyer May 29, 2008
    Very Helpful , Thanks
    Scholar:
  • 131 Answers
You can replace these your self if you can solder and are mechanical. there are two stk ic attached to a silver heat shield
You can call or on line give them the model number and tell them you are looking for the convergence ics The part store .com
www.partstore.com
Be careful unplug if it looks to hard please call your local tv shop the fix for a shop is around 250.00
Thanks doctor video
Posted on May 26, 2008
The Blue gun on my rear projectin TV is off. It
It's not likely as simple as a new resistor. The convergence circuit contains two (sometimes 3 in older sets) convergence ICs which are a common failure point along with a handful of resistors in the same circuit.
This is going to vary a lot by your location but in my experience a convergence circuit repair would run you anywhere from $150 to $250 depending on the price and availability of parts.This is only a ballpark figure. It may be less in some areas, I don't know.
May 24, 2010 | Toshiba 50H82 50" Rear Projection...
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem...
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Oct 12, 2009 | Toshiba 50H82 50" Rear Projection...
3 d images on toshiba 50hd82
This is a convergence issue, the stk392 ic's have failed on the convergence board, if you want to tackle this issue your self you will need soldering skills and a dvm. This is a common issue with all projection tv's.
Sep 01, 2009 | Toshiba 50H82 50" Rear Projection...
My Toshiba Big screen is showing double
hi! think the convergence is in need to be aligned. or you do have a defective convergence amplifier.
Aug 29, 2009 | Toshiba 50H82 50" Rear Projection...
Hyper board rebuild tosiba 50h82
there is a place in indiana that rebuilds them pts electronics 1800-844-7871 they are very quick
Dec 28, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50h82 convergence issue
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 11, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
