Question about Cerwin Vega LW12 Subwoofer
Sub woofer cuts on and off.
Theres a continous hum on the transformer even if woofer is not being used, and now it cuts on and off if i play with the audio out jacks it some times comes back on . I was wondering can the amp be replaced and if so where do i find contact info. thanks Israel
  • 2 more comments
  • Anonymous Oct 23, 2008
    I have similar prob. Just loud hum when turned on, happened shortly after lightning hit and smoked receiver through surge protector. Trying to decide to fix or replace?
  • scotty67 Jan 25, 2009
    i have the same problem when the sub is on it makes a humming noise
  • nocoverage Jan 29, 2009
    My LW 12 just started this same problem with the hum. Anyone know the solution?
  • underwoodd Mar 18, 2009
    I have a cerwin vega avs-sub8. I don't have the hum that everybody else is talking about. Mine shuts on and off . If I turn it up it goes into protection I think. If I turn it down it shuts off and stays off. I took it in and supposedly got it fixed but the problem is still there
I was rid on my hum just as soon as I took my plug out of my powerstrip and plugged directy into an outlet. Must be something to do with incomplete grounding. It has been working just fine every since I plugged it into the wall.
Posted on Feb 19, 2009
    Problem Solver:
  • 3 Answers
I am an Electronics Tech and just finished repairing a LW12 for a customer. It also has the HUM. IF I place a finger on the RCA input and another finger on the heatsink..(black metal plate at the back) then the hum goes away. I did notice that Cerwin V maunfactured this older LW12 unit with a 2 prong cord. I personally own a newer CV 10" sub, 3-prong and has never had a problem with it and it has awesome Bass. So for my customer...I am thinking I will add a 3-prong cord. and see what happens.....
Pv700 sub woofer has loud hum
If the speakers are turned off and the sound is still there , check the Amps , as it could be voltage transformer noise from the amp . This is caused by non sealing of the transformer .So I am told
Dec 17, 2013 | Boston Acoustics Audio Players & Recorders
Powered subwoofer has hum
First of all confirm if the hum is an internal or external problem.
Disconnect the RCA sub woofer input from the back of the unit and turn it on. If there is no hum it could be the interconnecting cable or the output from the receiver. But in the stand alone mode if the sub woofer hums when powered on you have internal problem and will have to be looked into by a professional.
Many a time the earth or the shield of the interconnecting cable is the culprit, because the sub sits on the floor and you might shift it for cleaning the floor and the cable can stretch and snap internally.
Apr 01, 2011 | JBL SCS145.5 System
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Amp cuts out
could be an internal problem such as a relay or resistor or something of the sort
Sep 02, 2009 | Car Audio & Video
I bought a sub woofer from a thrift store used and even though my existng computer speakers have a sub woofer jack, after hooking it up, it doesnt play. I bought the digital chord which fits well in the...
Different sound system use different voltages for their speakers. Look up in your computer manual what the electricial requirments are for the speakers and see if the one you bought matches.
Dec 15, 2008 | Computers & Internet
Humming sound
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
May 15, 2017 | Bose Lifestyle 12 System
2000 lexus es300
This is normal. I also have a 2000 ES300. This became a problem when i tried to run an aftermarket sub off of the wire leads from the stock sub-woofer. When I would switch the radio off there would be a loud, deep, constant bass tone. As far as I know you cannot stop the voltage from continuously supplying the sub-woofer this is the way the factory amplifier is programmed, however, if you cut one of the wires(youhave to cut because wires are soldered to sub-woofer) the humming noise will not occur when radio is shut off. Cut the wire in middle and add crimp connectors so you can reconnect later if needed. You only need to cut one and it doesn't matter whether it's the black or red wire.
Oct 02, 2008 | 2000 Lexus ES 300
Sub woofer hum sub333
Hum is caused by shielded audio cable positioned too close to mains transformer. Open rear side panels and locate twin grey shielded cables from second amplifier board going to little printed circuit board screwed to the back of the plastic box that covers all I/O connectors. Just reroute this cable so it has more distance to the transformer and the hum will be gone!
Aug 21, 2008 | Audio Players & Recorders
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Cerwin Vega LW12 Subwoofer Logo
568 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
