Question about RCA HD52W140 52" Rear Projection Television
Tv problem dead set
Rca tv model-HD52W140, resistors R14705,R14718,R14719-burns out-fed from flyback
  • RCA Master
  • 8,617 Answers
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
http://servicemanuals.vstore.ca/
Posted on May 20, 2008
Smelled smoke and hot wires, tv went off and never came back on again. opened back and found only one small part looked burned out, ( broken and a little brown on the board.) Part number R14705.
Thats a 27K 1/2 watt Carbon Composition resistor 5% tolerance. You got deflection issues so a replacement resistor will most likely fail unless you discover whaich componenet on the deflection board caused the resistor to burn. The deflection boards have been discontinued for your model which has the ATC321 chassis. But you can get a remanufactured ATC321 deflection board from www.tvrepairworld.com
Jun 12, 2011 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch tv
Clean Board Then Replace R14718 260880 And R14719 175046 And Hv Splitter 258512 And Horizontal Output Q14401.
Apr 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca TV HD52W58
The number you gave for the resistor is incorrect. But I did find a R14705. This resistor is a 1/2W 27K ohm resistor. This part is also in the deflection circuit. This is not a good circuit to play in, and resistor do not burn up by them selfs. There is a problem somewere neir by. The part number for this resistor is 238958.
Jul 31, 2008 | RCA HD52W58 52" TV
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
RCA projector HD65W140
It sounds like you have a real bad problem, Do your Circuit Board looks repairable? Was the burn thru the board? Are you saying you need the schematic for this TV? For more info ctechnicians.com
Jan 07, 2008 | Televison & Video
HD52W140YX!
Check first R14705 to see if burnt! If so then HV Trans is bad. Also if you need schematic try www.servicemanuals.net
Oct 08, 2007 | RCA HD52W140 52" Rear Projection...
RCA Scenium HD52W140 smoked
Hello Here is a link to get the schematic for this set: http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=%20D52W20 Thank you
Sep 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
yea i got my similar tv for 75 bucks blown hv splitter replace with bad resistor blew again 1 day later. i just replaced it tonight along with the flyback hopefully it works
Aug 02, 2007 | RCA HD65W140 65" Rear Projection...
RCA HD52W140 52" Rear Projection Television Logo
285 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
