Question about Whirlpool LEB6200 Electric Dryer
Dryer heats up but won't turn
When I push the power button on my dryer it won't start. When I set the time the element starts to heat but it doesn't spin. I hear no sounds other than the normal sound of the timer turning. When I push the power button I get nothing.
  • 7 more comments
  • Anonymous Jun 03, 2008
    the dryer will cut on and heat up but doesn't turn
  • Anonymous Jun 07, 2008
    I Turn it to the setting I want and it makes a sound like it wants to run and it heats up, but nothing moves
  • hecrazo Jun 26, 2008
    dryer heats up but it wont turn at all.
  • thumpher0120 Jun 29, 2008
    Our drier is heating up but not turning. We are trying to find the belt to see if it's broken but don't want to take too much apart. Do you have a diagram of the motor? It's a Whirlpool - Special Edition 3 cycle md# lgr3624-JQI. Thank you very much. thumpher0120@sbcglobal.net
  • ashlynsmom10 Jul 15, 2008
    My dryer stopped with 20 minutes left and will not restart. The clothes in the dryer were still warm.
  • SONJASIG34 Oct 17, 2008
    WHEN i TURN THE DRYER ON IT I HEAR A HUM AND IT HEATS UP BUT DOES NOT TURN.
  • Anonymous Oct 23, 2008
    I have a GE dryer, it heats up but will not turn.
  • ddalpaz Apr 25, 2009
    I have a Kenmore 70 series, when i set the dryer it will instantly heat up (without even pressing the start botton) but the drum wont spin when I try to start it. Another wierd thing is that when I press the start botton while the timer is set to 'OFF' it doesnt make the annoying "buzz"sound that it usually makes. Hmmmm, what to do, What to do.
  • cody lister Dec 09, 2012
    my dryer will cut on but turn off after 15 to 20 minutes it heats up but quits after a while
    Problem Solver:
  • 9 Answers
Perhaps you have a broken drum belt
Posted on Jun 24, 2008
This issue sounds like a dryer belt. It's actually relatively easy to disassemble a dryer. I found a great site that explains this at
http://repair2000.com/wpoolbelt.htm
If you have a Whirlpool Special Edition 3 cycle dryer, like I do,  here are a few additional dissassembly notes.
1)  Put a trashcan behind dryer to hold the top when you remove it. There's a wiring harness  that connects to the top control panel, and you don't want to damage it by letting the top hang by it.
2) There are 2 sheet metal screws one on each side on the inside of the front panel, remove them.  Then lift up on the front panel to free the bottom.
3) Don't bother disconnecting the door switch, just swing the front panel over to the right side of the dryer. It's handy to keep this connected for testing anyway.
4) An old pair of tennis shoes is about the perfect height to support the drum.
Good luck
Posted on Nov 08, 2008
I have a GE dryer, it heats up but will not turn. I have already checked the belt and it is fine. What other promlem could it be?
Posted on Oct 23, 2008
  • tdf77 Oct 23, 2008
  • 686 Answers
SOURCE: Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Posted on Mar 04, 2009
  • 262 Answers
SOURCE: My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Posted on Jan 08, 2008
barkencoa
  • 3463 Answers
SOURCE: dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Posted on Nov 30, 2008
  • 23 Answers
SOURCE: Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Posted on Apr 29, 2009
protek480
  • 1714 Answers
SOURCE: tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Posted on Jul 07, 2009
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
The heating element in my GE dryer I noticed the element will come on when the timer is set and without pushing the start button. The drum isn't turning when this occurs. The cabinet is still apart and...
There is a heater switch in side the motor that is bad have to replace the motor unfortnatly. The main power wires run thru the motor to the heater.
Jan 04, 2011 | Dryers
Hope this helps.
Thanks.
Nov 27, 2008 | Dryers
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Dec 20, 2007 | Kenmore 62822 Electric Dryer
Whirlpool LEB6200 Electric Dryer Logo
4,197 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
