Question about Microsoft Office Professional 2007 Full Version for PC
Powerpoint 2007 Eevery time when I start powerpoint 2007, displaying the information as following: powerpoint couldn't load the add-in C/PROGRAM~1/ CLICKT~1'OFFICE/ADDINs/ClickToConvert.ppa What does it mean and how I can solve it? Many thanks Grumiaux
  • peteritto Nov 24, 2008
    I have the same problem. I do all things, you wrote. But, powerpoint do the same. Where is the problem? What I have to do?
    Thank you Peter
  • 265 Answers
It can be removed and it will most likely continue to cause you problems if you don't. NOTE: Please do NOT attempt to edit your registry if you're not familiar with how to do so. You could render your computer useless, and the repairs to it could become rather expensive very easily. CLICK HERE.
Posted on May 29, 2008
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
Aug 17, 2011 | Microsoft Office Professional 2007 Full...
I can't get powerpoint 2007 to work.
Solution given by pankaj is very effective but in any case this method didn't work for you then use stellar phoenix powerpoint repair software to fix your problem.
Sep 09, 2009 | Microsoft PowerPoint 2007 for PC
I have word2000 and i want to open a word 2oo7 document how can i
Download this tools for Microsoft:
http://www.microsoft.com/downloads/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Please note that:
Overview Users of the Microsoft Office XP and 2003 programs Word, Excel, or PowerPoint—please install all High-Priority updates from Microsoft Update before downloading the Compatibility Pack.
By installing the Compatibility Pack in addition to Microsoft Office2000, Office XP, or Office 2003, you will be able to open, edit, andsave files using the file formats new to Word, Excel, and PowerPoint 2007.The Compatibility Pack can also be used in conjunction with theMicrosoft Office Word Viewer 2003, Excel Viewer 2003, and PowerPointViewer 2003 to view files saved in these new formats. For moreinformation about the Compatibility Pack, see Knowledge Base article 924074.
Note: If you use Microsoft Word 2000 or Microsoft Word 2002 to read or write documents containing complex scripts, please see http://support.microsoft.com/kb/925451 for information to enable Word 2007 documents to be displayed correctly in your version of Word.
Administrators: The administrative template for the Word, Excel, and PowerPoint converters contained within the Compatibility Pack is available for download.
Update: The Microsoft Office Compatibility Pack Service Pack 1 (SP1) is available here.
arrow_px_up.gif Top of page
System Requirements
  • Supported Operating Systems: Windows 2000 Service Pack 4; Windows Server 2003; Windows Vista; Windows XP Service Pack 1; Windows XP Service Pack 2
  • Recommended Microsoft Office programs:
    • Microsoft Word 2000 with Service Pack 3, Microsoft Excel 2000with Service Pack 3, and Microsoft PowerPoint 2000 with Service Pack 3
    • Microsoft Word 2002 with Service Pack 3, Microsoft Excel 2002 withService Pack 3, and Microsoft PowerPoint 2002 with Service Pack 3
    • Microsoft Office Word 2003 with at least Service Pack 1, MicrosoftOffice Excel 2003 with at least Service Pack 1, and Microsoft OfficePowerPoint 2003 with at least Service Pack 1
    • Microsoft Office Word Viewer 2003
    • Microsoft Office Excel Viewer 2003
    • Microsoft Office PowerPoint Viewer 2003
InstructionsTo install this download:
  1. Ensure your system is up to date by installing all High-Priority/Required updates on Microsoft Update (required for Microsoft Office XP and 2003 users).
  2. After installing all High-Priority/Required updates with Microsoft Update, download the Compatibility Pack by clicking the Download button above and saving the file to your hard disk.
  3. Double-click the FileFormatConverters.exe program file on your hard disk to start the setup program.
  4. Follow the instructions on the screen to complete the installation.
To remove this download:
  1. On the Windows Start menu, click Control Panel.
  2. Select Add/Remove Programs.
  3. In the list of currently installed programs, select Compatibility Pack for the 2007 Office system and then click Remove or Add/Remove. If a dialog box appears, follow the instructions to remove the program.
  4. Click Yes or OK to confirm that you want to remove the program.
P.S.: If this information was helpful, please rate this solution.
Mar 23, 2009 | Microsoft Office Professional 2007 Full...
Unable to open .pps attachments from windows mail in windowsvista
If you have Windows XP:
Manual fix
  • Click Start, Run and type CONTROL FOLDERS
  • In the Folder Options applet that opens, select the File Types tab
  • Scroll down and locate the following entry:
PPS (Microsoft PowerPoint Slide Show)
  • Click Advanced
  • Click the New button
  • Type Open in the the Action: text box
  • In the Application used to perform action: field, type the following exactly:
For PowerPoint Viewer 2003:
"C:\Program Files\Microsoft Office\PowerPoint Viewer\pptview.exe" "%1"
For PowerPoint Viewer 2007:
"C:\Program Files\Microsoft Office\Office12\pptview.exe" "%1"
  • Uncheck the Use DDE box
  • Click OK, OK
  • Close the Folder Options dialog
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows Vista Home Premium with...
Power point viewer 2007
libby68, if you have any part of 2007 you may be able to down-load PowerPoint Viewer 2007 at this site;
http://www.microsoft.com/downloads/details.aspx?familyid=048dc840-14e1-467d-8dca-19d2a8fd7485&displaylang=en
I'm not sure what it is you are asking for. Do you have a problem with your video graphics card? Or is there a problem while in PowerPoint Viewer 2007? What information do you need & for what program.
Mar 04, 2008 | Computers & Internet
Format powerpoint 2007 into powerpoint 2003
No prob. Follow these instructions
  1. Simply open the file in your current Office powerpoint program.
  2. Click "File"
  3. Click "Save As"
  4. Just below the name you add is another box called "save as type" Click the triangle on the right and save it as the format you need.
Good Luck!
Dec 06, 2007 | Microsoft Office Professional 2007 Full...
I need help with microsoft office 2007
The resolution appears to be two fold,
First of all you might want to add the following registry key depending on the application for which the user gets a prompt:
Click on Start Run then type in the following command for respective applications.
reg add HKCU\Software\Microsoft\Office\12.0\<application>\Options /v NoReReg /t REG_DWORD /d 1 For Ex:
reg add HKCU\Software\Microsoft\Office\12.0\Word\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\12.0\Excel\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\12.0\Outlook\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\12.0\PowerPoint\Options /v NoReReg /t REG_DWORD /d 1.
This should normally take care of the issue in applications like Outlook ,Word and Power point .
The user might also get a secondary error message when opening Excel application that states the following. stdole32.bmp
Note: Opening excel in the application safe mode would bypass the error. But this could be misleading coz the issue has more to do with permission than add-in within the application.
To resolve this problem you would need to perform the following steps:
1) Go to start > run > regedit
2) Navigate to the HKEY_CLASSES_ROOT > Excel.Chart.8
3) Right Click on key and select Permissions
4) In the Permission windows > Click on Add Tab and add everyone
5) Once this is done Click on the Advanced Tab > Owner > Highlight Everyone > Click on Apply and Ok
6) In the Permission > Select Everyone > enable the check box for Full Control and Read, then Click on Apply and Ok.
7) Click on F5 to refresh, this should create a new Sub key below Excel.Chart.8 called Protocol > Right Click on the key and repeat step 3 – 5.
8) Refresh again and follow the same sequence of steps to add permission to the following Sub keys StdFileEditing >Server.
9) Close the registry editor.
This should resolve the issue for good.
Dec 05, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
453 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
