Question about Achiever CCS5000 Shredder
Squeeling belt? How to replace?
SilentBob, thanks for the info you gave me about oiling the blades and/or replacing the belt. The oil did not work. So how do I go about replacing the belt. The instructions for the shredder give little info and no info on repairs. Do I have to call a service person?
Thanks,
NanaGil
A tech would be the best idea. The unit you own is chiniese and very hard to find parts for, so you may need to call around a little.
Posted on Jun 04, 2008
Lound squeling sound when running
chek oil level if low add if full replace oil pressure sensor as for the squeel it could be bad belts or if its teh 3.5 get your water pump and timming belt changed
Feb 16, 2014 | 1998 Chrysler Concorde
Do i need to replace blades? they spin but no longer grind
yes theres two posible solutions
first unplug any thing when working on it (be smart)
1st check to see if the blades are on right sometimes somepeople take the blades off and put them back on wrong sometimes theres a guild so the blades sit right sometimes not
2nd if that dont fixya up then yes the blades are bad simply replace them. and long as it turns it works
to help from having to replace the blades alot simply clean them and oil them light coat of veg. oil works and store them in a paper towel i hope this info fixya right on up
Mar 28, 2012 | Jura Capresso 501 Electric Blades Grinder
Air conditioner
The squeeling is the belt because the air compresor is likely seizing. At idle it can't turn the compressor, in motionthe compressor probably turns and cools the air. Most air conditioners come on when the defroster is on.
Jul 26, 2010 | 1996 Nissan Quest
My 2006 jeep wrangler was making a noise like a belt squeeling drove about 5 miles noise stopped engine light appeared and oil pressure went to 0 (Jeep only has 38,000 miles)I imediatly turned engine off i...
have truck scanned for code can be anything oil pump timing chain etc also check warranty before doing any work most drive trains 5yrs- 100,000 miles
Oct 07, 2009 | 2006 Jeep Wrangler
Mower squeeking - mowing as usual, and it's squeeking, checked oil, it has oil in it, what else should I check, mower 1 year old, I've done minimal maintenance on it. and can't find my owners manual.
Does it squeek when at an idle, or when driving, or cutting? Does it cut fine? I would check the belts and pulleys and blades for extra play. I had a mandrel bearing go bad on my ys4500 (also about a year old) and the first symptom was a squeeling sound when the blades were enguaged. Play in the mandrel caused the belt to squeek at the pulley that turns the blade. It also cut some nice gouges in my yard due to a floppy blade. I hope that this helps, I got the answers to my problem here on fixya.com.
I believe that one can find a downloadable .pdf version of the owners manual with a quick google search.
good luck
Jul 12, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Squeels at start for first two seconds
The squeeling could be from a worn belt or if oil drips on belt overnight. Replace the belt first to see if that fixes it.Good luck.
Dec 30, 2008 | 2002 Jeep Liberty
Serpentine belt squeeling
To replace the sepentine belt: Get a 9/16 socket with a extension. Look under the car and look for the oil filter. Next to the oil filter you will see a bolt. Use the sock and losen the bolt. This will losen the tensioner. You will notice the bolt coming out, push the bolt up and the tensioner will allow you to remove the belt.
Dec 29, 2008 | 2006 Hyundai XG350
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Achiever CCS5000 Shredder Logo
56 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
