E Machine modelT2885 will not turn on at all, switch test good
  • 3,940 Answers
Most likely failure point if the system doesn't power on at all, (No leds, no fans, no noise) is the power supply.
You can buy a standard ATX power supply for around $30
Here is one on-line source:
http://www.pcpower.com/power-supply/silencer-310-atx.html
Posted on May 20, 2008
The water continues to fill tube even with machine turned off.
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Jan 11, 2017 | Washing Machines
Ariston washing machine front loader keeps spewing out water from the top of washing machine lid
Washer fills with water and overflows:
Dec 08, 2016 | Ariston Technologies Washing Machines
Water will not enter machine
WHEN U SAY THE WATER SWITCH IS GOOD Have u dont a voltage test as well as a OHMS meter reading? As it can test good for ohms and still be bad electronically. the only other thing to check is the water pressure switch but my bet is with the water inlet valve or bad control board issue
Jun 15, 2014 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire gallery front load - can putting a heavy load of towels in machine and running it on permanent press cycle, make machine flood
highly unlikely.
Bythe way my advice is free cuz God is good!
Jun 03, 2014 | Frigidaire Washing Machines
Our estate washing machine has flooded our house TWICE! First time insurance cleaned it up... Now it's your turn.
May 07, 2014 | Estate Washing Machines
Washer error on rinse cycle
E11 means the Fill time is too long. There are a whole bunch of tests to perform - but the easiest is to replace the hoses going into the machine - I had the same problem and tested my hoses - they looked fine - but my machine would do this every so often - turns out my hoses had "check valves" that were a safety design to prevent freeflowing incase one burst.....well the valve was going bad. Replaced both hoses - never had a problem again. But anyways... here are the other tests...
1. Is the incoming water flow normal?
Yes. Go to step (4). No. Go to step (2)
2. Are the incoming water faucets turned completely on?
No. Turn water faucets on. Yes. Go to step (3).
3. Is the incoming water pressure above (30) psi.
No. Have customer correct pressure problem.
Yes. Check for kinked or blocked incoming water hoses, clean
the incoming water screens. If problem still remains, replace the
water inlet valve assembly.
4. Does the fill water continue enter the washer?
Yes. Go to step (5). No. Go to step (6)
5. Remove power from the washer. Did the water fill
stop?
Yes. Go to step (6) No. Replace the inlet valve assembly.
6. Good models, check the pressure switch.
Pressure switch checks good. Go to step (8).
Pressure switch checks bad. Replace pressure switch.
7. Better models, replace the pressure sensor.
If this did not correct the problem, go to step 8.
8. Replace the control board.
Good Luck!!!
GOOD LUCK!!!!
Apr 05, 2014 | Frigidaire ATF6000ES Front Load Washer
Washing machine will not stop filling during rinse cycle resulting in an FE error
Aug 14, 2012 | LG WM-1832C Front Load Washer
Hello When the main power switch is turned on,
Do you have a stitch pattern selected and a length chosen? Otherwise it does not know what you want to do. Sometimes companies neglect to tell you that little fact. Also, how about your bobbin winding shaft, is it pushed all the way to the left? Other than that I am baffled. Good luck.
Sep 28, 2010 | White Sewing 1740 Mechanical Sewing...
How to inspect side-b-side freezer ther-stat and tell if bad.
Good day,
Looking at the defrost thermostat is a waste. It's true the disk will sometimes show a bulge, but not always. It's test is to be in an environment where the temperature is 0 to 30 degrees and have been there for at least a half hour. Then a continuity test with a VOM meter should show zero ohms. No resistance.
If by defrost switch, you mean timer, the basic test is to advance it until the machine shuts off. With the machine left turned on, the machine (if the timer is good) will turn itself back on in no more than 35 minutes. If not, it's bad and needs replaced.
In the real world of appliance repair, it's done the other way around.
First test the main heater with the ohm meter. It should read 35 ohms or less. If it looks good, and tests good, then replace the defrost tstat and timer and call it duty.
Here's an excellent tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Apr 22, 2010 | Kenmore Refrigerators
Computers & Internet Logo
David Payne
David Payne
