Question about HP Officejet J5780 All-In-One InkJet Printer
Help have connected and installed printer and it still will not print
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Check whether you have successfully installed the software or not and then check whether you have the printer icon in printers and faxes folder. if we do not have the printer icon then remove the USB cable from the computer and then insert the CD and click on add a device option and follow the onscreen instructions and connect the USB cable when prompts and then try to print. If we have the printer icon check the status, if the status is not in 0 ready then clear all the pending documents and then print. If we are still unable to print then download the print diagnostic utility from the HP website and run it.
Posted on May 26, 2008
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
I have connect usb cable and did all the instruction from manual and it doesn,t print i need help
1. Connect to a USB port on your computer, NOT on a hub. This might solve the problem.
2. Your computer hasn't found the printer drivers. Manually install them (download from Canon website) If when connected the printer does not show on your "Devices and Printers" panel, then the drivers have not been installed.
3. Try another USB cable in case it is faulty.
4. Make sure you have removed all transit packaging (if any) from inside the printer, and have set the ink cartridges correctly.
5. When you try to print, does a warning sign appear in your system tray? If so, do what it tells you.
6. If all else fails, read the installation instructions again, step by step.
Hope this helps.
Jan 27, 2013 | Canon IP2700 Inkjet Printer
How to connect my printer to a router
This model Canon printer has onlt an USB connection to a computer.
The only way to connect this printer to a router is to install a printer server with an USB connector, connect the printer to the print server and then connect the print server to the router using a LAN cable.
The printer driver needs to be installed on all the computers on your network and then to the printer properties then Port tab and add a TCP/IP port then configure this port with the print server's IP address.
Do a test print and if the test print is OK then printer is installed correctly.
May 29, 2012 | Canon iP2700 Inkjet Photo Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a printer clx-2160 ! It could not print black well but now that problem has been fixed ! I have windows 7 on my com and I have installed the printer driver but when I want to print a page from my...
You might have been installing the printer the wrong way.
1. Un-install the drivers and software for this printer.
2. Disconnect the printer from the computer.
3. Install the driver again and follow the on-screen instructions.
Do only connect when the installer asks to do so...
Latest driver and software (select driver / software tab).
Jul 28, 2011 | Samsung CLX-2160N All-In-One Printer
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer not printing
Make sure all cables are connected first. You may need to verify that the printed is installed correct by going to control panel and then to printers. Verify the printer is listed. If not you'll need to install it first. If installed and listed. Go to device manager and make sure driver is installed. You might even try to update driver by going to Printer Manufacturer website. Any more info would also help solve. Hope this helps. Thanks
Feb 19, 2008 | Office Equipment & Supplies
HP Officejet J5780 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
