Question about Foxconn K7S741MG-6L Motherboard
Pin Outs Cannot locate a diagram for USB ports, reset button, and all the other stuff for the front of the cpu unit for the K7S741MG-6L mother board
  • clueless738 Feb 04, 2009
    I do not have the pin outs for power connections for the k7s741mg-6l motherboard.
    Guru:
  • 1,342 Answers
Get your manual and drivers HERE
Posted on May 20, 2008
Driver windows
the video card has the drivers on the dvd disk
Jan 22, 2014 | Foxconn K7S741MG-6L Motherboard
Bios rom checksum error.. system halted
This error comes when there is low cmos voltage so motherboard flash memory forgot the bios settings.
For that open cpu and then pull cmos cell from mother board buy new cmos cell and replaced it.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios and set time and date and boot option in bios then save settings.
Then it works again if it not works then you need to update firmware for your bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Foxconn K7S741MG-6L Motherboard
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Video output
April fools?
make sure the power is on, cables connected, all components are working and installed correctly?
Apr 01, 2008 | Foxconn K7S741MG-6L Motherboard
H P 15-1443-000-0375-6533 power defect
P-8 is an extra for optional added items. Sounds like your power supply unit took a few jolts. The fine wires in the motor are under high tension. If too many snap, the frays cause a short and the unit won't power up. Try replacing that before you go buy a ton of stuff.
Dec 27, 2007 | HP (399542-B21) 700-Watt Power Supply
Foxconn K7S741MG-6L Motherboard Logo
191 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
