Question about Motorola Mobility RAZR V3
Bluetooth Connection to Mazda Handsfree Is No Longer Handsfree
My Razr no longer connects automatically to my Mazda CX9 handsfree feature. I can connect manually, but each time I exit and reenter my Mazda I must reconnect again. I don't know if the problem is with the Mazda or my Razr. Can you give my any suggestions?
Thanks
  • Miker70 Sep 25, 2008
    I'm having the same problem with my Blackberry 8830. The car knows about the phone, and finds it if I go through the setup menus, but I have to do this everytime I start the car.
  • 103 Answers
bluetooth connect is only going to work for up to 30ft in distance so if you go to far from the car it will disconnect because it lost the bluetooth signal.
please rate me. thank you.
Posted on May 22, 2008
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
Tried to upgrade software via bluetooth connection, flash erase failed, now screen is unable to be read and phone is no longer paired
Maybe cause the upgrade was fail and then you will have to make it replaced or checked. (this is the screen which is the brain and not the box).
Jan 02, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
How to connect nokia 70 with motorola handsfree
is it motorola handsfree headset??
if so...
activate bluetoth of ur nokia cell,
activate the handsfree (pressing long the on off button,for connecting with new device)
1, it automaticaly send the connection request to nokia cell
2 if not, go to paired devices of ur nokia cell blutooth and search more devices.
select motorola handsfree,
enter passcode 0000
it will work.
May 01, 2009 | Motorola Mobility Bluetooth Hands-Free...
Pairing
press and hold the button (on/off button) on the ear piece until the light becomes blinking blue and red. Turn on the bluetooth scanner of your phone and search. Select the handsfree and pair them. Simple.
If you turn on your handsfree and the light is blinking purple, that means you need to turn off the handsfree and restart with holding on to the button on the ear piece.
Feb 02, 2009 | Itech Clip IIe Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth , handsfree
when you select your connectivity you should see sync and BT there
Jun 01, 2008 | Motorola Mobility RAZR V3
Motorola h350 blue tooth headset microphone does not work
4.Select H350 once a connection is detected.
Tips:
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Phone won't recognise handsfree
try doing a master reset and master clear that looking for it again....that should work and may sure that the handsfree bluetooth is active.,so the mobile can find it.
Nov 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
575 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
