Question about Dell Inspiron B130 Notebook
Worn power connection
Do you happen to know how to fix the worn dell power connection? I was going to take out the power connection from the board and have a new one soldered on but if there is an easier way I would prefer that.
  • jgerber May 20, 2008
    Thanks Rick.
I have had to do this a few times. firstly, go to ebay and search "b130 power jack' and buy it. next print or write down the instructions from the service manual fount on the dell website ( they sound intimidating but really its not that bad). when you get to the motherboard de-solder the connection and throw the faulty jack out, resolder a new one in (using lowest wattage possible on the soldering iron) and put all the innards back in. I had never taken a laptop apart nor soldered before and mine worked fine afterward.
Posted on May 21, 2008
    Scholar:
  • 72 Answers
Well, if it's just the soldering points that are weaking then you don't need a new one. Just resolder those points (probably won't even take any extra solder but i would recommend giving it a little more so it doesn't just break again) and you should be fine. If the actual jack is damaged then you'll have to replace it. No real ease here, though, as you'll have to take the laptop apart either way.
Posted on May 20, 2008
  • Rick White
    Rick White May 20, 2008
    No problem! Good luck!
In a dell e177fpf lcd monitor all the capasitors fuses diodes in power supply and inverter board are ok.but the back lights remains 2 seconds.
Hello...I recently opened up my Dell E173Fpf monitor because the screen went black, yet the power button was green. I thought it was a capacitor problem. But before doing anything I gave the board a thorough inspection, looking for anomalies. I observed a substance, (later identified as silicon) puddled around the power connections. I gently removed the semi rigid stuff and didn't touch the capacitors as I had originally planned. I partially reassembled the monitor for a test run and it worked again. (Being 9 years old, I don't know for how long...) Only thing I can think of is that a spill happened at the factory and over the years it gradually "melted" to puddle around the wires behind the power input. (Weird, but that seems to be what happened.)
Dec 05, 2014 | Dell 17" e177fpf lcd monitor black
Orange light blinking will not power on
Call dell. I do know there is alot of issue with Dell motherboards and that is the pattern of them is the blinking light.
Sep 16, 2010 | Dell XPS 410 PC Desktop
Lcd monitor Dell model E193FPc works for about one minute then goes black, and the power light blinks like is in the sleep mode
Look for bad caps and shorted out transisotrs in the power supply/inverter board: http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Aug 30, 2010 | Dell E193FPC 19" TFT LCD Flat Panel...
My dell E151fpb 15' monitor screen turns white
Look for loose connection between the LCD panel T-CON board and the logic board first, it may also have lost the 5vdc for the T-CON board.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 05, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
Have a dell e177fp monitor. When I power on it only displays for 3 seconds and shuts off. Green power light remains on.
You need to check the voltages and components in the power supply/inverter board first. It should have 5vdc for logic and 12~16vdc for the backlight innerter circuits.
There are three version of the boards for this model.
http://lcdrepair.us/Invpowersupply.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jul 08, 2010 | Dell E177FP LCD Monitor
ACER ASPIRE MODEL-ZO3 IS NOT DETECTING POWER SUPPLY
BOARD PROBLEM, SHORTAGE BRING TO THE EXPERT TECHNICIAN THAT IS NEED TO OPEN THEN FIXE THE BOARD IF POSIBLE SOME DELL THATS HAPPEN. LIKE DELL 630M,DELL 6000..CUASE OF UNPROPERLY SHUTDOWN..
Sep 16, 2009 | Dell Latitude D600 Notebook
Picture ok for a few minutes then go blank
it is your monitor inside problem, you need to know follow issue:
1) inverter board some where the component got less connection
like MOSFET drive or capacitor swelling need to resoldering or change.
2) the back light lamps worn that most cause this symptom, need check or adjust inverter driver to match them work well
3) DC power supply filter capacitor swelling should be this problem, check and fix it.
hope help you something do well, please feedback any question any time,
pleaae take a rating let me know how much helped you thanks!
May 27, 2009 | Dell E176FP 17" LCD Monitor
Dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
Mar 19, 2009 | Dell Dimension 8200 PC Desktop
Dell Optiplex 755 Orange Power light
I don't know what happened before this but If you have your Operating system CD, then insert it into the drive, boot from CD and follow instructions to repair your operating system or install a fresh copy.
If this does not work, then I would like to know what happened first before you started having this problem.
Nov 10, 2008 | Computers & Internet
Dell Inspiron B130 Notebook Logo
75 people viewed this question
Alun Cox
