Question about Samsung SGH-D900 Cellular Phone
Bluetooth when i try to switch my bluetooth on the the activating bluetooth sign just spins without switching on. its a samsung d900. also on the activation page the red dot is in the off box and sometimes when i try to activate it, it says already activated. please help
    Brigadier General:
  • 7,752 Answers
Do a hard reset *2767*3855#
Posted on Jun 03, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Hi there: I cant send or receive photos on my samsung D900 do i need to configure somsthing in settings?. thanks-Terry
You need to contact your cellular service provider and verify that your MMS service has been activated on your account. Without MMS being activated you won't be able to 'Picture Message'.
Jan 24, 2011 | Samsung SGH-D900 Cellular Phone
Bluetooth wont switch on
try to look at the bluetooth menu if it's visibility is ON. if not. you should turn it on so the other pairing devices can read your bluetooth..
Aug 30, 2009 | Samsung J700 Cellular Phone
Password
if this would be the first time that your going to activate it, it should be 0000 or 00000000
Jun 26, 2009 | Samsung SGH-D900 Cellular Phone
Bluetooth fails to deactivate
the chip of bluetooth works with the smal program on the cellphone.  there are two option. software or chip is broke down. should go to service.
May 29, 2009 | Samsung SGH-D900 Cellular Phone
Cannot activate bluetooth
Can be a common problem with Samsungs, Have seen it a few times. It is a software glitch. you will need it re-flashed with the phone firmware. Any repairs shop should be able to do this for you.
I could help you, but am probably not local enough to be able to, you will more than likely have a local repair shop
Apr 16, 2009 | Samsung SGH-D900 Cellular Phone
Ref: bluetooth symbol on continously draining the battery
its not the bluetooth symbol, it's the GPRS symbol, you can desactivate it by doing *#4777*8665# and then desactivate it and also clicking "activate manually' or something like that...
Aug 19, 2008 | Samsung SGH-D900 Cellular Phone
Bluetooth activation D900
do a hard reset of the phone *2767*3855#
Feb 08, 2008 | Samsung SGH-D900 Cellular Phone
My Samsung D900 freezes when I activate bluetooth
Bluetooth module needs to be replaced. Bluetooth module gets to be faulty very easy, because it is on the side of the phone, so just a small drop can damage it. There is a glue around it, it this is cracked your phone is already out of warranty due to customer abuse. Other thing what can appear with your phone is short battery life.
Sep 20, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
125 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
