Question about Mitsubishi XL8U Multimedia Projector
Mitsubishi XL8U Projector
Having two problems:
1. When showing videos, emits green hue. Also when not projecting, projector emits a green hue on screen.
2. Projector cuts out (projecting blue) and then in again. This happens sporadically.
Is it the bulb?
  • 563 Answers
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
Posted on May 22, 2008
Noticed a yellow hue in the centre of the image projected by BOTH of my second-hand Sony VPL PX40's.
Bit of a common problem with Sony projectors of the era that they often had problems with fading and/or cracking of one or more the LCD panels - especially the blue ones for some reason, leading to the type of problem you are experiencing. No point in swapping components either as they will both have similar faults - although replacing an LCD in a video projector is almost impossible without the manufacturers jigs to mechanically align them afterwards anyway...
Mar 25, 2014 | Sony VPL PX40 Multimedia Projector
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
We have used our projector for years, but are now having a problem with the picture. The picture that shows on the screen is shown in a red/purple hue. Any suggestion on how to fix?
Are you using component video inputs? You could check the green connectors on both ends of the video inputs. They sometimes develop a poor connection. I would not throw a lot of money at it. It was a good projector in its day but they sell used on ebay or craigslist for $100 - $300 now.
Hope this helps,
Feb 19, 2011 | InFocus ScreenPlay 4805 Multimedia...
Projector is working but intensity problem,, display is not good
Have you changed the brightness setting or put the projector into eco mode. ?
Also see what mode your dvd player is in (same on projector) they can have film modes which reduce the brightness.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Mitsubishi XL8U Multimedia Projector
Mitsubisi XL8U
The XL8U will tell you when the lamp needs replacement. There is a yellow box that will appear telling you so. The lamp is easy to replace, the model number is VLT-XL8LP.
Mar 18, 2009 | Mitsubishi XL8U Multimedia Projector
Mitsubishi XL30U Green Haze
This projector has three LCD screens followed by a prism to converge the screens and project the light. Lack of maintenance is the usual cause.
If the lamp is old, it will produce more and more UV light that will burn, usually the first colour, the blue LCD panel giving a greenish hue starting from the centre of the screen and working outwards.
If the filters are blocked, this will damage the LCD screens.
The screens are available from Mitsubishi but maybe cheaper to replace the projector as they are very expensive and fitting is a specialised job.
Jun 15, 2017 | Mitsubishi ColorView XL30U Multimedia...
Projector Problems
There is some problem in your LCD Panels. Service the optical unit ant retry.
regards
Viren
Jun 30, 2008 | Office Equipment & Supplies
I have a Mitsubishi xl8u projector, with approx 2000 hrs max on its first lamp. Of late, the projected image has attained a blue tinge to its edges which is getting progressively worse and seems to be...
Hi Bob
This most definitelly NOT the lamp.
It is unfortunatelly your Mainboard that is at fault , and will either need repair or replacement as this will only get worse as time passes.
Hope this is of help !
Apr 20, 2008 | Mitsubishi XL8U Multimedia Projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Mar 15, 2008 | Mitsubishi XL8U Multimedia Projector
Projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Nov 12, 2007 | Mitsubishi XL8U Multimedia Projector
Mitsubishi XL8U Multimedia Projector Logo
406 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
