Rank: Apprentice
Rating: 100%, 1 votes
Do you have to tap on the left lower side (facing the T.V) are the lines thin and white?
Has the T.V. ever turned off by itself?
This set was made in Mexico and Panasonic have HAD problems with dirty solder joints, "dry solder joints" as thay are called, expand and "open" with heat and age. Thay can "fix themself's" when the set is allowed to cool down or if you tap the joint back together. That is untill the set gets hot again and the joint expands and.........you get the picture?
Try re soldering your power supply solder joints, you MUST desolder and clean joints!
Hope this helps, sorry about the delay never been on this site untill today!
See Ya from Waterloo, Ontario CANADA.
