Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
BLACK BOX ON SCREEN DURING DVD PLAYBACK
WITH TWO DIFFERENT DVD PLAYERS,I HAVE GOTTEN A BLACK BOX IN THE LOWER THIRD OF THE SCREEN.THE BOX IS ABOUT A FOURTH OF THE TOTAL SCREEN.I SUSPECTED IT WAS A DEFECTIVE DVD PLAYER,AND THE SECOND PLAYER WORKED PERFECTLY FOR ONE MONTH,THEN THE BOX REAPPEARED.COULD A PET HAVE STEPPED ON THE TV REMOTE IN SOME BIZARRE WAY TO CAUSE THIS?? HELP!!!
THE TOSHIBA WEB SITE ADVISED ME IT WAS SIMPLY THE CLOSED CAPTION TURNED ON...I TURNED IT OFF...PROBLEM GONE! (I STILL BLAME MY LITTLE DOG FOR STEPPING ON THE REMOTE CONTROL..HAHA!)
Posted on May 21, 2008
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
Aug 20, 2009 | Brady CODESOFT 7 Premier (cs7-prem-usb)
Black box won't go away during DVD play
is it just during dvd's or does it happen at other times
Sep 25, 2008 | Sony KP-53S35 53" Rear Projection...
Lines across the screen occur during playback on sony dvp-ns700h
make sure its set to progresive scan that will get rid of any lag
Jul 09, 2009 | Sony Televison & Video
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Go Video Playback Problem
Have you checked the NTSC/PAL setting of your DVD?
Feb 25, 2008 | Curtis DVD8017 Portable DVD Player
Slow DVD playback
Playing DVD's requires a bit of constant transfer from the drive to the controller and from the controller to the RAM. First thing I would try is disabling background programs. One very likely culprit is if you have anti-virus software that is running a scan in the background.
Have you tried different DVD's? The problem could be the DVD drive is not reading the DVD properly. Have you tried different players? Different players sometimes work better. I would also suggest making sure that your sound drivers are up to date.
Nov 12, 2007 | Computers & Internet
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
I am having problems hooking it up to an HD Receiver from Direct TV
playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Oct 29, 2006 | Samsung DVDR120 DVD Recorder
Black Box
i had the same problem with my rca truflat.. i read from a posting of a similar problem with a different tv brand to switch your closed caption options 'off' or set it to a 'cc' option instead of the 't' options.. (this was done through the on-screen menu..) i gave it a try and it worked for my tv.. hope it works for you..
Aug 16, 2006 | RCA 20F610TD TruFlat TV/DVD
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
