Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 3600 series
The record arm comes over to the record magazine and then stops. I cannot get magazine to move even when I put it on scan.
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
Posted on May 25, 2008
  • Dave Jukebox Nov 13, 2008
    The gripper arm should be over the magazine to start with. That's the 'home' position. When it is in that position it clicks a microswitch at the base of the gripper am and that completes the circuit to move the carousel and either scan or rotate to another selection.
    By physically pulling the latch at the side of the carousel you are bypassing that circuit so it will rotate anyway. The solenoid that isn't pulling in actually pulls in that latch that you are moving with your finger.
    Dave F.
1978 Wurlitzer tone arm
Your cartridge may need cleaning and reinstalling....remove the tone arm and check you wires for any kind of damage or wear.. ..you can use a multimeter to check for resistance in each wire..(ohm's)..you should get ZERO resistance...
Jul 09, 2017 | Wurlitzer Audio Players & Recorders
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer super star juke box. the
I think I can clear things up for you. The free play switch you're referring to is just to add credits. If you want continuous free play, I sell you a jumper plug to bypass the credit unit, commonally called BOAC, if you have a 3600 series Super Star. Please email tech@wurlitzer-ohio.com.
Mar 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Dec 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Going to move my Wurlitzer 1015 300 miles. What do I have to do to stabalize the unit on the inside? Ron
If this is the original 1015 jukebox from 1945/46, plays either 24 X 45RPM or 78RPM records, then you need to remove all the records and their trays, secure the tone arm with some tape to its post, make sure the amplifier is locked in place, and then I would put an old sleeping bag or similar (pillow) into the space to the right of the record stack to prevent the turntable platter from banging up when you lay the machine on its back for transportation. Put a bit of tape on the straight bubble tubes to stop them from sliding out of their heaters - do this at the top of the tube and just leave the tape in place permanently.
When you arrive, first make sure that all the bubble tubes are in place, seated in their heaters, then check for loose parts, check the amp's tubes are seated, remove pillow, remove tape from tone arm, load records, cross your fingers and turn it back on.
Oct 15, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer OMT, takeout arm continues to cycle all the time
There is a white bracket on the far side of the gripper arm which comes loose so it doesn't click the microswitch beneath it. To prove this press o the bracket when the arm is over the cd magazine and it will stop.
Oct 11, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm frozen w/ one digit flashing 8 then E w/o top of E
At the far side of the white nylon gears at the base of the gripper arm is a small white 'duck bill' bracket, which clicks a microswitch when the gripper is over the carousel. When it breaks or comes loose it fails to click the microswitch and the arm doesnt stop.
Dave F.
Mar 11, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer 3600
email me at philhemmings@hotmail.com so i can send you an attachment for the jukebox that may help you
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
312 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
