Question about Xerox Office Equipment & Supplies
Tcpip is disable on a xerox 8550 printer. How to enable it manually
    President:
  • 2,072 Answers
Here are the steps to set up a static IP on your printer.
  1. With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
  5. If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
  6. If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
  7. Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
  8. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
  9. Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  10. Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
  11. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
  12. Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  13. Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
  14. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
  15. Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  16. Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
Posted on May 20, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Printing from a parallel port to a USB printer
Do a Google search for parallel to usb and you should find all kinds of info. It seems that Belkin makes one. Check it out.
Mar 17, 2009 | Xerox Phaser 8550/DT Thermal Printer
ERROR MESSAGE 8550/DT
I can check if I find the service manual.
Oct 28, 2008 | Xerox Phaser 8550/DT Thermal Printer
Xerox phaser 8550 printer
You can print out a configuration page, It will contain the serial number.
Sep 16, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
233 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
